The help file shows it as sendemail: http://homeseer.com/support/homeseer..._sendemail.htm. Which documentation shows it incorrect?
Cheers
Al
SendMail problems - Object doesn't support this property
Nevermind....
have to use hs.SendEmail !! (but the documentation says SendMail)
Brian
Hi all,
Maybe this has been discussed, but not seeing it in the forum.
Has something changed with HS3 SendMail?
I have this command in a vbs script, but does not work....
hs.sendmail "to@abc.com","from@abc.com","cc@abc.com","","***","***",""
I have tried numerous combinations. Email subsystem works because there are events which send me email.
I get this error....
Running script, script run or compile error in file: C:/Program Files/HomeSeer HS3/scripts/CHECKIP.VBS438:Object doesn't support this property or method: 'hs.sendmail' in line 47 More info: Exception from HRESULT: 0x800A01B6Tags: None
