Error running called script via &hs.DeviceScriptButton_AddButton
    &hs.DeviceScriptButton_AddButton. The button presses call a separate (for now) corresponding .net script whose only purpose is to trigger an existing HS3 event.
     &hs.DeviceScriptButton_AddButton("126", "Off", 607001, "yamahaavroffbutton.vb",  "ZMain", "Yamaha AVR Off", 1, 1, 1)
     &hs.DeviceScriptButton_AddButton("126", "On", 607002, "yamahaavronbutton.vb",  "ZMain", "Yamaha AVR On", 1, 2, 1)
    The buttons populate and successfully call the scripts located in the /scripts folder when pressed.
     Imports System.IO
     Imports System.Text
     Imports System.Net
     Public Sub ZMain(Parms As Object)
     Dim ParmArray() As String
     ParmArray = Parms.ToString.Split("|")
     Dim hs3devid As String = (ParmArray(0))
     Dim hs3action As String = (ParmArray(1))
     hs.TriggerEvent("Yamaha AVR Off")
     End Sub
    However, the script fails with the following log message:
    Running script yamahaavroffbutton.vb :Exception has been thrown by the target of an invocation.->Does entry point ZMain exist in script? at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Obj ect obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a()
    Any suggestions you can offer are appreciated!
    The problem is Objec vs String
    The problem is Objec vs String, convert the object parsed by the button to an string:
    Sub xxxxx(parameters as object)
    Dim dvRef As Integer = parameters(0) 'Integer - The device reference ID.
    Dim Value As String = parameters(1)
    Hope this helps
      Dropping the string split & those changes did it - thanks very much!
