activate device script button from a txt script
    I have made a device with device script buttons.
    When I push the buttons, the script that has to be run is running.
    But if I change the state of the device by an other script (.txt) with
    hs.SetDeviceValueByRef devref, 100, True
    hs.setdevicestring devref, "On", True
    The device goes on, but the script of the device button does not run.
    What am I doing wrong?
    Peter
    http://ohh.pcgsm.nl
    Hi Peter,
    You need to use CAPI commands. Search the board for "capigetsinglecontrol" for some examples.
    Cheers
    Al
    PS Here's on recent thread. See post #10 and later. http://board.homeseer.com/showthread.php?t=163760
      For help with constructing CAPI script statements, take a look at tenScriptAid.
      tenholde
      tenholde
        Wow, that is awesome!
        If that can't get people to understand CAPI, then nothing will!
          hs.CAPIControlHandler(hs.CAPIGetSingleControl(cv,true ,"On",false,true))
          is working perfect!
          Peter
          http://ohh.pcgsm.nl
            tenholde
            When I want to connect to HS, I get this error:
            Error retrieving Devices from HS3: Object reference not set to an instance of an object.
            Peter
            http://ohh.pcgsm.nl
              Could you select the debug box before connecting?
              The HS log will show you where the tenScriptAid log is written.
              Please post log contents here.
              tenholde
              tenholde
                is working perfect!
                Is there also a command to read if a module is on or off?
                Like replacement for hs.IsOn?
                Peter
                http://ohh.pcgsm.nl
                  Look at the Capi Status value, it should show current status from the CapiControls available for that device:
                  if hs.CAPIGetStatus(924).Status.ToUpper.Contains("ON") then    xxxxxxxxxxx
                  tenholde
                    Since you are not controlling a device, you can also get the device's value using hs.devicevalue. However, you'd have to know what the specific values are for on and off as this is not consistent across all types of devices/plugins. Off is typically 0, but On could be 1, 99, 100, 255.
                    Cheers
                    Al
                      tenholde
                      This is the log:
                      12/5/2015 23:01:41 | tenScriptAid started
                      12/5/2015 23:01:41 | Clipboard set to:
                      12/5/2015 23:01:41 | tenScriptAid Startup Complete
                      12/5/2015 23:01:47 | Attempting to connect to: 192.168.1.20
                      12/5/2015 23:01:47 | HS3 connection successful
                      12/5/2015 23:01:47 | HS version: 3.0.0.208
                      12/5/2015 23:01:47 | Retrieving HS3 Devices
                      12/5/2015 23:02:47 | Exception retrieving Devices: Object reference not set to an instance of an object.
                      Can it be that the device Reference ID of the latest device is too high?
                      Latest device has Reference ID 2451.
                      I have done a lot of testing creating devices and delete them.
                      I now have 687 devices
                      Peter
                      http://ohh.pcgsm.nl
                        That helps. Did the log not show any devices that it found?
                        tenholde
                          No, that is all in the log file.
                          Peter
                          http://ohh.pcgsm.nl
                            Not likely as my latest reference is quite a bit higher than that and so is my latest device count and it's working fine for me.
                            Cheers
                            Al
                              The error you are getting is before it successfully retrieves even the first HS3 device while enumerating.
                              Please try version 1.14, adds more debug info during Device Retrieval.
                              Please post debug results.
                              Thanks for your patience,
                              tenholde
                              tenholde
