Funny, I had the exact same issue occur with the Homeseer Ocelot plugin with the 1st input of a SECU16 device. It consistantly creates a bad device.
It's a shame Homeseer won't support their own code.
activate device script button from a txt script
That did the trick!
The program stopped at a device and it was a device, created with an Ocelot plugin.
This plugin was modified to also use IR and variables. But it was working only for 1 secu16 unit. (and the creator of the flugin did not respond anymore on my mails for help.)
That made me decide to buy ethernet boards with relais and inputs.
They are working now, but I still had the Ocelot devices.
I have deleted all existing Ocelot devices and now the program is working ok!
Thanks for your help!
peterpc,
I've built a utility that instead of using HS3 enumeration to retrieve all devices (which is failing on your installation), it attempts to retrieve Devices with a DevRef of 1-10000.
I'm hoping it fails on a specific device so we can narrow down what is happening.
Please download and run the FindBadDevice utility and let me know what happens.
tenholde
peterpc,
Could you define a few things about your configuration.
You are running on remote computer, correct?
Same LAN?
What OS, etc. is HS3 running on. What OS, etc are you running tenScriptAid on?
What plugins are installed.
The hs.GetDeviceEnumerator call is failing. There is some message board traffic about this -- I'm doing further research.
Looking at reported problems with plugins that use PlugExtraData, and you try to access stuff remotely. Especially if the plugin places custom objects into PlugExtraData.
Linux base HS3 does not properly serialize remote objects, and even on Win, if a plugin uses a custom object in the PlugExtraData, the plugin must be available for the remote caller for deserialization.
Please provide what you can, and I will keep researching.
If you feel adventurous, stop all of your plugins and see if that helps. If it does, keep adding plugins back until it fails.
Not sure any of this is the problem. Still looking.
tenholde
12/6/2015 17:32:27 | Attempting to connect to: 127.0.0.1
12/6/2015 17:32:27 | OpenHsConnection called with: 127.0.0.1
12/6/2015 17:32:27 | CreateClient successful, CommunicationState: Disconnected
12/6/2015 17:32:27 | Attempting to Connect, this is attempt number: 1
12/6/2015 17:32:27 | client.Connect attempted, CommunicationState: Connected
12/6/2015 17:32:27 | host should now be good ServiceProxy
12/6/2015 17:32:27 | Attempting to get APIVersion through Proxy
12/6/2015 17:32:27 | Successfully retrieved APIVersion through the host Proxy: 3
12/6/2015 17:32:27 | Now trying: hs=host
12/6/2015 17:32:27 | OpenHsConnection appears to have completed successfuly
12/6/2015 17:32:27 | HS3 connection successful
12/6/2015 17:32:27 | HS version: 3.0.0.208
12/6/2015 17:32:27 | Retrieving HS3 Devices
12/6/2015 17:32:27 | Getting Enumerator
12/6/2015 17:33:27 | Exception retrieving Devices: Object reference not set to an instance of an object.
The error you are getting is before it successfully retrieves even the first HS3 device while enumerating.
Please try version 1.14, adds more debug info during Device Retrieval.
Please post debug results.
Thanks for your patience,
tenholde
Originally posted by peterpc View Post
Can it be that the device Reference ID of the latest device is too high?
Latest device has Reference ID 2451.
I have done a lot of testing creating devices and delete them.
I now have 687 devices
Cheers
Al
Originally posted by tenholde View PostCould you select the debug box before connecting?
The HS log will show you where the tenScriptAid log is written.
Please post log contents here.
tenholde
12/5/2015 23:01:41 | tenScriptAid started
12/5/2015 23:01:41 | Clipboard set to:
12/5/2015 23:01:41 | tenScriptAid Startup Complete
12/5/2015 23:01:47 | Attempting to connect to: 192.168.1.20
12/5/2015 23:01:47 | HS3 connection successful
12/5/2015 23:01:47 | HS version: 3.0.0.208
12/5/2015 23:01:47 | Retrieving HS3 Devices
12/5/2015 23:02:47 | Exception retrieving Devices: Object reference not set to an instance of an object.
Originally posted by peterpc View PostIs there also a command to read if a module is on or off?
Like replacement for hs.IsOn?
Cheers
Al
Look at the Capi Status value, it should show current status from the CapiControls available for that device:
Code:if hs.CAPIGetStatus(924).Status.ToUpper.Contains("ON") then xxxxxxxxxxx
