Energy math scripting
    Hi,
    Hopefully someone can send me in the right direction.
    I have found a combine code for wattage, this script only combine watt and update a virtual device with the current W output. Triggered by "change" in reading
        hs.setDeviceString(197,"",True)
        hs.setDeviceString(197,(hs.deviceValue(98) +hs.deviceValue(95)) & "Watt",True)
    End Sub
    The next script i wanna make is adding specific kWh readings each day as a total amount into a virtual device.
    Then reset the value every month back to zero.
    Can anyone help me with the coding? =)
