Low Battery Warning Script?
    OK, who has a nice script that will text me if a low-battery warning is received from any motion sensor? Preferably it will include the location of the sensor, but not absolutely necessary.
    Jim Speiser
    Still don't know squat
    In this post is a nice little script that will update a virtual device with the lowest battery level. You can trigger emails or other warnings off of the virtual device.
    Mike posted a script in this post that will generate a nicely formatted report of all batteries.
    I use the virtual device to trigger a message with the full report when any battery is low. I also email the report to me on the first friday of each month so I can replace batteries over the weekend.
    Randy Prade
    Aurora, CO
    Prades.net
      Tried it, but...
      I tried this script, but I get an exception in the Log:
      Jan-10 1:54:43 PM Error Exception in script LowBatteryCheck: Object reference not set to an instance of an object.
      Jim Speiser
        I see that it is designed for Z-wave; will it also work with Insteon motion sensors?
        Jim Speiser
          I just added this in (not sure how I missed this awesome script), and it works for me. Did you make sure to put the refID in the event for the script to see your virtual device?
            I am sure you can make it work. Right now it is looking for a device type of Zwave batteries... you would just need to change this line to match what it is for insteon... I don't have any so I am not sure what it will look like:
            If StrComp(dv.Device_Type_String(Nothing), "Z-Wave Battery") = 0 Then  'Only work with devices with a battery
              The report I pointed to above uses "if device type contains 'battery'", so it catches all battery devices. I'm sure the script could be changed accordingly. I never bothered, because all of my battery operated devices are Z-Wave.
              Randy Prade
              Aurora, CO
              Prades.net
                I would need to take a refresher course on vbscript. Can you tell me the function name I would use to replace strComp (which IIRC is a full string comparison) to do a partial string comparison (or just "does the string contain")?
                Thanks.
                EDIT: Actually, never mind. As far as I know, Motion Sensors are the only Insteon devices that report a battery condition, so I could just strComp on Motion Sensor Battery Low or whatever.
                Jim Speiser
                  Thanks.
                  I am not a proficient script writer, but replacing "strComp" with "InStr" should allow you to "string contains" comparison. The report I linked to above used the following:
                  If InStr(UCase(dv.Device_Type_String(Nothing)), "BATTERY") > 1 Then
                  It will report all device types that have battery in them. It just uses a different approach of making the string uppercase then looking for "BATTERY" in the string.
                  Randy Prade
                  Aurora, CO
                  Prades.net
