Matching Value Script
    I'm looking for the following script.
    One of my insteon devices isn't sending the value (dim level) to HStouch. I want to create a virtual device and have that device dim to the same level as the insteon switch and use the value from the virtual within HS. I have done it before with an event but that was just for on and off. Cant seem to find a way to match values.
    Not that it is impossible to do I would wonder if it is more feasbile to work out why the Insteon device does not work. If the dim value range has the controluse property set to dim does it not appear correctly?
      It appears properly in HS3 but not in HST.
        Anyone?
          I have a script that can be easily modified to do that. Will post it later today.
          Cheers
          Al
            Thanks Al!!!
              Here's the script that I use:
              Sub Main(ByVal Parms as String)
              	Dim ParmArray() as String
              	ParmArray = Parms.tostring.split(",")
              	dim targetDev1 as Double = CDbl(ParmArray(0))		'reference ID of the device to use for existing value
              	dim targetDev2 as Double = CDbl(ParmArray(1))		'reference ID of the device to set based on value of targetDev1
              	dim Debug as Boolean = True
              	Dim logName = "Dim Follower"								'set log name for HS log
              	Dim dev1Value,dev2Value As Double
              	dev1Value = hs.DeviceValue(targetDev1)
              	dev2Value = hs.DeviceValue(targetDev2)
              	If Debug Then hs.writelog(logName,CStr(targetDev1) & ":" & CStr(dev1Value))
              	If dev1Value <> dev2Value Then
              		Select Case dev1Value
              			Case 1 to 98
              				' Device DIM, set its current dim level
              				hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev2, false, CStr(dev1Value), false, true))
              				If Debug Then hs.writelog(logName,CStr(targetDev2) & ":" & CStr(dev1Value))
              			Case 99
              				' Device ON, set it to on
              				hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev2, false, "On", false, false))
              				If Debug Then hs.writelog(logName,CStr(targetDev2) & " Set to On")
              			Case 0
              				' Device OFF, set it to off
              				hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev2, false, "Off", false, true))
              				If Debug Then hs.writelog(logName,CStr(targetDev2) & " Set to Off")
              		End Select
              	Else
              			If Debug Then hs.writelog(logName,"Devices are at same value already")
              	End If
              End Sub
              You need to pass two variables to it, the device reference id of the device that is the "master", and then the reference id of the slave device that needs to "follow", separated with a comma. Save the file with a .vb extension and then create an event that triggers every time the master device changes. For the event action, run the script passing those device reference ids to it. The script was created to allow a real device to change based on another device. Since you are planning on a virtual slave device to follow the master, you may need to replace the hs.CAPIControlHandler command with:
              hs.SetDeviceValueByRef(targetDev2, dev1Value, True)
              Hope that helps.
              Cheers
              Al
