Help Identifying Part of this Script
    I found this script on the forum(old thread), the script has been updated for HS3, but I don't understand part of it.
    Please look at image below.
    1. I believe is the Device Name
    2. Device Code
    3. I believe this say if OfficeTestDoor is open, then speak "Warning, the Office Test Device has tripped!"
    4. What does this say or mean. Why is this needed?
    Any ideas helping me gain better understanding of it ?
    Tom
    1. I believe is the Device Name This is a variable and it can really be anything you want but it helps if the variable is named something you can remember. It will be set to True if the device code is on
    2. Device Code Correct
    3. I believe this say if OfficeTestDoor is open, then speak "Warning, the Office Test Device has tripped!" Correct
    4. What does this say or mean. Why is this needed? The true is "Description: If set to TRUE, the function will not return until the system finishes speaking. This is useful if you are switching between speaking and listening. You cannot listen and speak at the same time on some systems. If this parameter is missing, the system will not wait."
    The other parameters are the speaker clients you want to send the speech to.
    -Rupp
      Rupp beat me to it.
      Jeff Farmer
      HS 3, HSPhone
        Thank you both!
        Exciting when you start understanding what at first looks like gibberish.
        Tom
