what to change to run this script on Linux?
    Hi I have a nice script which works fine when used on Hs3 Windows. But now changing over to Hs3 on Linux its not working any more and giving errors.
    How to change this to get it working on Linux as well?
    I have no scripting skills so hopefully it is just some simple changes that need to be made
    Thanks in advance W.
    The Error running the script as .vb:
    jan-21 09:56:27         Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Not valid as identifier.
    jan-21 09:56:27         Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected end of statement.
    jan-21 09:56:27         Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected 'End'.
    jan-21 09:56:23         Event    Running script in background: /usr/local/HomeSeer/scripts/afvalophaalscript.vb
    And the script itself(parts are in Dutch):
    Public Sub Main()
        Dim Postcode, Huisnummer, Toevoeging, DevRef, Debug
        Dim objHttp, Text, i, Ophaaldagen
        Dim Datum, d
        ' Vul hier je eigen gegevens in
        Postcode = "2514CB"
        Huisnummer = "1"
        Toevoeging = ""
        DevRef="179"
        Debug="0"  '0=off, 1=on
        ' Ander test adres
        'Postcode = "8266bh"
        'Huisnummer = "1"
        'Toevoeging = ""
        Set objHttp = CreateObject("Msxml2.ServerXMLHTTP")
        objHttp.Open "GET", "http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=" & Postcode & "&street=&huisnummer=" & Huisnummer & "&toevoeging=" & Toevoeging & _
            "&platform=phone&langs=nl&mobiletype=android&platform=phone&version=33%20HTTP/1.1", False
        objHttp.Send
        Text = objHttp.ResponseText
        Set objHttp = Nothing
        If Len(Text) > 10 Then
            Set oJSON = New aspJSON
            oJSON.loadJSON(Text)
            'Get single value
            if Debug = "1" then hs.writelog "afval", "Response: " & oJSON.data("response")
            if Debug = "1" then hs.writelog "afval", "Gemeente: " & oJSON.data("data")("gemeente")
            Datum = Year(now()) & "-" & Right("0" & Month(Now()),2) & "-" & Right("0" & Day(Now()),2)
            if Debug = "1" then hs.writelog "afval", "Datum: " & chr(13) & Datum
            Ophaaldagen = ""
            For Each i In oJSON.data("data")("ophaaldagen")("data")
                Set this = oJSON.data("data")("ophaaldagen")("data").item(i)
                Ophaaldagen = Ophaaldagen & this.item("type") & ": " & this.item("date") & this.item("type") & ": " & this.item("date") & chr(13)
                d = this.item("date")
                if Debug = "1" then hs.writelog "afval", "d: " & chr(13) & d
                If d >= Datum Then
                  Hs.setdevicestring DevRef, this.item("type") & ": " & this.item("date"), true
             if this.item("type") = "restafval" then Hs.setdevicevaluebyref DevRef, 1, true
             if this.item("type") = "gft" then Hs.setdevicevaluebyref DevRef, 2, true
             if this.item("type") = "papier" then Hs.setdevicevaluebyref DevRef, 3, true
             if this.item("type") = "plastic" then Hs.setdevicevaluebyref DevRef, 4, true
                  Exit For
                End If
            Next
            If Debug = "1" then hs.writelog "afval", "Ophaaldagen: " & chr(13) & Ophaaldagen
        Else
            if Debug = "1" then hs.writelog "afval", "No data received. Location probably not supported by mijnafvalwijzer.nl."
        End If
        End Sub
        'Februari 2014 - Version 1.17 by Gerrit van Kuipers
        Class aspJSON
           Public data
           Private p_JSONstring
           private aj_in_string, aj_in_escape, aj_i_tmp, aj_char_tmp, aj_s_tmp, aj_line_tmp, aj_line, aj_lines, aj_currentlevel, aj_currentkey, aj_currentvalue, aj_newlabel, aj_XmlHttp, aj_RegExp, aj_colonfound
           Private Sub Class_Initialize()
              Set data = Collection()
               Set aj_RegExp = new regexp
               aj_RegExp.Pattern = "\s{0,}(\S{1}[\s,\S]*\S{1})\s{0,}"
               aj_RegExp.Global = False
               aj_RegExp.IgnoreCase = True
               aj_RegExp.Multiline = True
           End Sub
           Private Sub Class_Terminate()
              Set data = Nothing
               Set aj_RegExp = Nothing
           End Sub
           Public Sub loadJSON(inputsource)
              inputsource = aj_MultilineTrim(inputsource)
              If Len(inputsource) = 0 Then Err.Raise 1, "loadJSON Error", "No data to load."
              select case Left(inputsource, 1)
                 case "{", "["
                 case else
                    Set aj_XmlHttp = CreateObject("Msxml2.ServerXMLHTTP")
                    aj_XmlHttp.open "GET", inputsource, False
                    aj_XmlHttp.setRequestHeader "Content-Type", "text/json"
                    aj_XmlHttp.setRequestHeader "CharSet", "UTF-8"
                    aj_XmlHttp.Send
                    inputsource = aj_XmlHttp.responseText
                    set aj_XmlHttp = Nothing
              end select
              p_JSONstring = CleanUpJSONstring(inputsource)
              aj_lines = Split(p_JSONstring, Chr(13) & Chr(10))
              Dim level(99)
              aj_currentlevel = 1
              Set level(aj_currentlevel) = data
              For Each aj_line In aj_lines
                 aj_currentkey = ""
                 aj_currentvalue = ""
                 If Instr(aj_line, ":") > 0 Then
                    aj_in_string = False
                    aj_in_escape = False
                    aj_colonfound = False
                    For aj_i_tmp = 1 To Len(aj_line)
                       If aj_in_escape Then
                       Else
                          Select Case Mid(aj_line, aj_i_tmp, 1)
                             Case """"
                                aj_in_string = Not aj_in_string
                             Case ":"
                                If Not aj_in_escape And Not aj_in_string Then
                                   aj_currentkey = Left(aj_line, aj_i_tmp - 1)
                                   aj_currentvalue = Mid(aj_line, aj_i_tmp + 1)
                                   aj_colonfound = True
                                   Exit For
                                End If
                             Case "\"
                                aj_in_escape = True
                          End Select
                       End If
                    Next
                    if aj_colonfound then
                       aj_currentkey = aj_Strip(aj_JSONDecode(aj_currentkey), """")
                       If Not level(aj_currentlevel).exists(aj_currentkey) Then level(aj_currentlevel).Add aj_currentkey, ""
                    end if
                 End If
                 If right(aj_line,1) = "{" Or right(aj_line,1) = "[" Then
                    If Len(aj_currentkey) = 0 Then aj_currentkey = level(aj_currentlevel).Count
                    Set level(aj_currentlevel).Item(aj_currentkey) = Collection()
                    Set level(aj_currentlevel + 1) = level(aj_currentlevel).Item(aj_currentkey)
                    aj_currentlevel = aj_currentlevel + 1
                    aj_currentkey = ""
                 ElseIf right(aj_line,1) = "}" Or right(aj_line,1) = "]" or right(aj_line,2) = "}," Or right(aj_line,2) = "]," Then
                    aj_currentlevel = aj_currentlevel - 1
                 ElseIf Len(Trim(aj_line)) > 0 Then
                    if Len(aj_currentvalue) = 0 Then aj_currentvalue = aj_line
                    aj_currentvalue = getJSONValue(aj_currentvalue)
                    level(aj_currentlevel).Item(aj_currentkey) = aj_currentvalue
                 End If
              Next
           End Sub
           Public Function Collection()
              set Collection = CreateObject("Scripting.Dictionary")
           End Function
           Public Function AddToCollection(dictobj)
              if TypeName(dictobj) <> "Dictionary" then Err.Raise 1, "AddToCollection Error", "Not a collection."
              aj_newlabel = dictobj.Count
              dictobj.Add aj_newlabel, Collection()
              set AddToCollection = dictobj.item(aj_newlabel)
           end function
           Private Function CleanUpJSONstring(aj_originalstring)
              aj_originalstring = Replace(aj_originalstring, Chr(13) & Chr(10), "")
              aj_originalstring = Mid(aj_originalstring, 2, Len(aj_originalstring) - 2)
              aj_in_string = False : aj_in_escape = False : aj_s_tmp = ""
              For aj_i_tmp = 1 To Len(aj_originalstring)
                 aj_char_tmp = Mid(aj_originalstring, aj_i_tmp, 1)
                    aj_s_tmp = aj_s_tmp & aj_char_tmp
                 Else
                    Select Case aj_char_tmp
                       Case "\" : aj_s_tmp = aj_s_tmp & aj_char_tmp : aj_in_escape = True
                       Case """" : aj_s_tmp = aj_s_tmp & aj_char_tmp : aj_in_string = Not aj_in_string
                       Case "{", "["
                          aj_s_tmp = aj_s_tmp & aj_char_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10))
                       Case "}", "]"
                          aj_s_tmp = aj_s_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10)) & aj_char_tmp
                       Case "," : aj_s_tmp = aj_s_tmp & aj_char_tmp & aj_InlineIf(aj_in_string, "", Chr(13) & Chr(10))
                       Case Else : aj_s_tmp = aj_s_tmp & aj_char_tmp
                    End Select
                 End If
              Next
              CleanUpJSONstring = ""
              aj_s_tmp = split(aj_s_tmp, Chr(13) & Chr(10))
              For Each aj_line_tmp In aj_s_tmp
                 aj_line_tmp = replace(replace(aj_line_tmp, chr(10), ""), chr(13), "")
                 CleanUpJSONstring = CleanUpJSONstring & aj_Trim(aj_line_tmp) & Chr(13) & Chr(10)
              Next
           End Function
           Private Function getJSONValue(ByVal val)
              val = Trim(val)
              If Left(val,1) = ":"  Then val = Mid(val, 2)
              If Right(val,1) = "," Then val = Left(val, Len(val) - 1)
              val = Trim(val)
              Select Case val
                 Case "true"  : getJSONValue = True
                 Case "false" : getJSONValue = False
                 Case "null" : getJSONValue = Null
                 Case Else
                    If (Instr(val, """") = 0) Then
                       If IsNumeric(val) Then
                          getJSONValue = CDbl(val)
                       Else
                          getJSONValue = val
                       End If
                    Else
                       If Left(val,1) = """" Then val = Mid(val, 2)
                       If Right(val,1) = """" Then val = Left(val, Len(val) - 1)
                       getJSONValue = aj_JSONDecode(Trim(val))
                    End If
              End Select
           End Function
           Private JSONoutput_level
           Public Function JSONoutput()
              dim wrap_dicttype, aj_label
              JSONoutput_level = 1
              wrap_dicttype = "[]"
              For Each aj_label In data
                  If Not aj_IsInt(aj_label) Then wrap_dicttype = "{}"
              Next
              JSONoutput = Left(wrap_dicttype, 1) & Chr(13) & Chr(10) & GetDict(data) & Right(wrap_dicttype, 1)
           End Function
           Private Function GetDict(objDict)
              dim aj_item, aj_keyvals, aj_label, aj_dicttype
              For Each aj_item In objDict
                 Select Case TypeName(objDict.Item(aj_item))
                    Case "Dictionary"
                       GetDict = GetDict & Space(JSONoutput_level * 4)
                       aj_dicttype = "[]"
                       For Each aj_label In objDict.Item(aj_item).Keys
                           If Not aj_IsInt(aj_label) Then aj_dicttype = "{}"
                       Next
                       If aj_IsInt(aj_item) Then
                          GetDict = GetDict & (Left(aj_dicttype,1) & Chr(13) & Chr(10))
                       Else
                          GetDict = GetDict & ("""" & aj_JSONEncode(aj_item) & """" & ": " & Left(aj_dicttype,1) & Chr(13) & Chr(10))
                       End If
                       JSONoutput_level = JSONoutput_level + 1
                       aj_keyvals = objDict.Keys
                       GetDict = GetDict & (GetSubDict(objDict.Item(aj_item)) & Space(JSONoutput_level * 4) & Right(aj_dicttype,1) & aj_InlineIf(aj_item = aj_keyvals(objDict.Count - 1),"" , ",") & Chr(13) & Chr(10))
                    Case Else
                       GetDict = GetDict & (Space(JSONoutput_level * 4) & aj_InlineIf(aj_IsInt(aj_item), "", """" & aj_JSONEncode(aj_item) & """: ") & WriteValue(objDict.Item(aj_item)) & aj_InlineIf(aj_item = aj_keyvals(objDict.Count - 1),"" , ",") & Chr(13) & Chr(10))
                 End Select
              Next
           End Function
           Private Function aj_IsInt(val)
              aj_IsInt = (TypeName(val) = "Integer" Or TypeName(val) = "Long")
           End Function
           Private Function GetSubDict(objSubDict)
              GetSubDict = GetDict(objSubDict)
              JSONoutput_level= JSONoutput_level -1
           End Function
           Private Function WriteValue(ByVal val)
              Select Case TypeName(val)
                 Case "Double", "Integer", "Long": WriteValue = val
                 Case "Null"                  : WriteValue = "null"
                 Case "Boolean"               : WriteValue = aj_InlineIf(val, "true", "false")
                 Case Else                  : WriteValue = """" & aj_JSONEncode(val) & """"
              End Select
           End Function
           Private Function aj_JSONEncode(ByVal val)
              val = Replace(val, "\", "\\")
              val = Replace(val, """", "\""")
              'val = Replace(val, "/", "\/")
              val = Replace(val, Chr(8), "\b")
              val = Replace(val, Chr(12), "\f")
              val = Replace(val, Chr(10), "\n")
              val = Replace(val, Chr(13), "\r")
              val = Replace(val, Chr(9), "\t")
              aj_JSONEncode = Trim(val)
           End Function
           Private Function aj_JSONDecode(ByVal val)
              val = Replace(val, "\""", """")
              val = Replace(val, "\\", "\")
              val = Replace(val, "\/", "/")
              val = Replace(val, "\b", Chr(8))
              val = Replace(val, "\f", Chr(12))
              val = Replace(val, "\n", Chr(10))
              val = Replace(val, "\r", Chr(13))
              val = Replace(val, "\t", Chr(9))
              aj_JSONDecode = Trim(val)
           End Function
           Private Function aj_InlineIf(condition, returntrue, returnfalse)
              If condition Then aj_InlineIf = returntrue Else aj_InlineIf = returnfalse
           End Function
           Private Function aj_Strip(ByVal val, stripper)
              If Left(val, 1) = stripper Then val = Mid(val, 2)
              If Right(val, 1) = stripper Then val = Left(val, Len(val) - 1)
              aj_Strip = val
           End Function
           Private Function aj_MultilineTrim(TextData)
              aj_MultilineTrim = aj_RegExp.Replace(TextData, "$1")
           End Function
           private function aj_Trim(val)
              aj_Trim = Trim(val)
              Do While Left(aj_Trim, 1) = Chr(9) : aj_Trim = Mid(aj_Trim, 2) : Loop
              Do While Right(aj_Trim, 1) = Chr(9) : aj_Trim = Left(aj_Trim, Len(aj_Trim) - 1) : Loop
              aj_Trim = Trim(aj_Trim)
           end function
        End Class
    You have two "end Function", rather than "End Function", which, looking at the errors, is what may be causing the issue. unix\linux is typically a lot more case sensitive than Windows. Try changing those and see what happens.
    Cheers
    Al
      I changed that but still the same errors.
      jan-22 15:53:39      Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Not valid as identifier.         jan-22 15:53:39      Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected end of statement.         jan-22 15:53:39      Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected 'End'.         jan-22 15:53:39      Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected end of statement.         jan-22 15:53:39      Error    Compiling script /usr/local/HomeSeer/scripts/afvalophaalscript.vb: Expected 'End'.         jan-22 15:53:35      Event    Running script in background: /usr/local/HomeSeer/scripts/afvalophaalscript.vb
        I know this script afvalwijzer..
        Try this one !
        PHP Code:
        Public Sub Main()
        Dim PostcodeHuisnummerToevoegingDevRefDebug
            Dim objHttp
        TextiOphaaldagen
            Dim Datum
        d
            Postcode = "2514CB"
            Huisnummer = "1"
            Toevoeging = ""
            DevRef="179"
            Debug="0"  '
        0=off1=on
        ' Ander test adres
        Postcode "8266bh"
            'Huisnummer = "1"
        Toevoeging ""
        Set objHttp CreateObject("Msxml2.ServerXMLHTTP")
        objHttp.Open "GET""http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=" Postcode "&street=&huisnummer=" Huisnummer "&toevoeging=" Toevoeging _
        "&platform=phone&langs=nl&mobiletype=android&platform=phone&version=33%20HTTP/1.1"False
            objHttp
        .Send
            Text
            Set objHttp
        Nothing
                Set oJSON
        = New aspJSON
                oJSON
        .loadJSON(Text)
        'Get single value
                If Debug = "1" then hs.writelog "afval", "Response: " & oJSON.data("response")
                If Debug = "1" then hs.writelog "afval", "Gemeente: " & oJSON.data("data")("gemeente")
                If Debug = "1" then hs.writelog "afval", "Datum: " & chr(13) & Datum
                Ophaaldagen = ""
                    If d >= Datum Then
                 If this.item("type") = "restafval" then Hs.setdevicevaluebyref DevRef, 1, true
                 If this.item("type") = "gft" then Hs.setdevicevaluebyref DevRef, 2, true
                 If this.item("type") = "papier" then Hs.setdevicevaluebyref DevRef, 3, true
                 If this.item("type") = "plastic" then Hs.setdevicevaluebyref DevRef, 4, true
                      Exit For
                    End If
                Next
            Else
            End If
            End Sub
        Februari 2014 Version 1.17 by Gerrit van Kuipers
        Class aspJSON
        Public data
        private aj_in_stringaj_in_escapeaj_i_tmpaj_char_tmpaj_s_tmpaj_line_tmpaj_lineaj_linesaj_currentlevelaj_currentkeyaj_currentvalueaj_newlabelaj_XmlHttpaj_RegExpaj_colonfound
        Set data Collection()
                   aj_RegExp
        .Pattern "\s{0,}(\S{1}[\s,\S]*\S{1})\s{0,}"
                   aj_RegExp
        .IgnoreCase True
                   aj_RegExp
        .Multiline True
               End Sub
        Set data Nothing
                   Set aj_RegExp
        Nothing
               End Sub
        inputsource aj_MultilineTrim(inputsource)
                  If
        Len(inputsource) = 0 Then Err.Raise 1"loadJSON Error""No data to load."
        select case Left(inputsource1)
                     Case
        Case else
        Set aj_XmlHttp CreateObject("Msxml2.ServerXMLHTTP")
        aj_XmlHttp.open "GET"inputsourceFalse
                        aj_XmlHttp
        .setRequestHeader "Content-Type""text/json"
        aj_XmlHttp.setRequestHeader "CharSet""UTF-8"
        aj_XmlHttp.Send
                        inputsource
                        set aj_XmlHttp
        Nothing
                  End select
                  p_JSONstring
        aj_lines Split(p_JSONstringChr(13) & Chr(10))
        Dim level(99)
        aj_currentlevel 1
                  Set level
                     aj_currentkey
        aj_currentvalue ""
        If Instr(aj_line":") > 0 Then
                        aj_in_string
        False
                        aj_in_escape
        False
                        aj_colonfound
        False
        For aj_i_tmp 1 To Len(aj_line)
                           If
        aj_in_escape Then
                              aj_in_escape
        False
        Else
        Select Case Mid(aj_lineaj_i_tmp1)
                                 Case
        aj_in_string Not aj_in_string
        Case ":"
                                       aj_currentkey
        Left(aj_lineaj_i_tmp 1)
        aj_currentvalue Mid(aj_lineaj_i_tmp 1)
        aj_colonfound True
        Exit For
        End If
                                 Case
                                    aj_in_escape = True
                              End Select
                           End If
                        Next
                        End if
                     End If
                        aj_currentkey = ""
                     End If
                  Next
               End Sub
               End Function
               End function
                     Else
                           Case "
                           Case "
                           Case "
                           Case "
                        End Select
                     End If
                  Next
                  Next
               End Function
                  val = Trim(val)
                  If Left(val,1) = "
                  If Right(val,1) = "
                  val = Trim(val)
                  Select Case val
                     Case "
                     Case "
                     Case "
                     Case Else
                           Else
                              getJSONValue = val
                           End If
                        Else
                        End If
                  End Select
               End Function
                  wrap_dicttype = "
                  Next
               End Function
                        Case "
        Dictionary"
                           aj_dicttype = "
                           Next
                           Else
                           End If
                        Case Else
                     End Select
                  Next
               End Function
               End Function
               End Function
                     Case "
                     Case "
                     Case "
                  End Select
               End Function
        \b")
        \f")
        \n")
        \r")
        \t")
               End Function
        \b", Chr(8))
        \f", Chr(12))
        \n", Chr(10))
        \r", Chr(13))
        \t", Chr(9))
               End Function
               End Function
                  aj_Strip = val
               End Function
        $1")
               End Function
                  aj_Trim = Trim(val)
               End function
            End Class
        Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
        HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
          @Malosa No, still getting the same errors. But as mentioned I am running this on the Linux version of Hs3
            That all looks to be VBScript to me which is unsupported in Linux - you would need it re-written to be in .net instead.
              Ok I do not know either of them, so if someone can help changing it into .net (.vb) would be great ?
                Good catch Adam. Typically I see a lot of other errors if I try to run a vbscript as a .vb file
                Cheers
                Al
                  Sorry , nl_user ask this at the dutch forum , the Guy who created this script... I cant rebuild iT in .net sorry ....
                  Sended from far far away
                    Cheers
                    Al
                      I posted this question also on the Dutch forum. Thanks for your support.
