This script is straight from the docmentation.
sub main()
' listen only for attention phrase
hs.ListenForCommands FALSE
end sub
For some reason it fails with the following error:
Running script, script run or compile error in file: C:/Program Files/HomeSeer HS3/scripts/Listen_Test.txt5:Invalid procedure call or argument: 'hs.ListenForCommands' in line 4 More info: Invalid procedure call or argument: 'hs.ListenForCommands'
Does the syntax need to be altered for HS3? I did try several things but nothing helped.
Gardner,
Current Date/Time: 2/16/2016 11:53:20 AM
HomeSeer Version: HS3 Standard Edition 3.0.0.208
Operating System: Microsoft Windows 7 Home Premium - Work Station
System Uptime: 1 Day 22 Hours 13 Minutes 49 Seconds
IP Address: 192.168.1.30
Number of Devices: 206
Number of Events: 23
Enabled Plug-Ins
3.0.0.14: Applied Digital Ocelot
3.0.0.17: iAutomate RFID
1.0.0.11: Random
3.0.5579.15955: Ultra1Wire3
3.0.0.36: X10
3.0.1.25: Z-Wave
sub main()
end sub
Gardner,
Enabled Plug-Ins
1.0.0.11: Random
3.0.0.36: X10
3.0.1.25: Z-Wave
