Script to find Z-wave node
    Can't seem to find this in the docs... what is the correct way to enumerate thru devices to find the node number of a Z-Wave device?
    Don
    Bump
    Don
      Originally posted by donstephens View Post
      Bump
      Hi Don,
      What are you trying to accomplish with it? What info do you have that you want to pass to the script and then have it return the node number?
      Cheers
      Al
        Hi Al;
        I'm trying to get the node numbers from all the Z-Wave devices. I have had failed comm problems from nodes from time to time and I'd like to have a script that goes through all the Z-Wave devices and reports the node #.
        Don
        Don
          The best place to get that is the Node Information page in the Z-Wave plugin. If you still want a script, here's a quick one that will report the nodes to a .txt file:
          Public Sub Main(ByVal parm As Object)
                  Dim dev As Scheduler.Classes.DeviceClass
                  Dim sw As System.IO.StreamWriter
                  Dim pdata As clsPlugExtraData = Nothing
                  Dim pk() As String
                  Dim s As Object
                  Dim x As Integer
                  Try
                      sw = New System.IO.StreamWriter("DumpZWaveDevices.txt", False)
                      Dim EN As Scheduler.Classes.clsDeviceEnumeration
                      EN = hs.GetDeviceEnumerator
                      If EN Is Nothing Then Throw New Exception("failed to get a device enumerator from HomeSeer.")
                      Do
                          dev = EN.GetNext
                          If dev Is Nothing Then Continue Do
                          pdata = dev.PlugExtraData_Get(hs)
                          If (pdata IsNot Nothing) Then
                              pk = pdata.GetNamedKeys()
                              If (pk IsNot Nothing) Then
                                  For x = 0 To pk.Length() - 1
                                      s = pdata.GetNamed(pk(x))
                                      If (pk(x) = "node_id") Then
                                          sw.WriteLine("ref=(" & dev.ref(hs) & ") - " & dev.Location(hs) & " - " & dev.Location2(hs) & " - " & dev.Name(hs) & ":  " & pk(x).ToString() & " = " & s.ToString())
                                      End If
                                  Next
                              End If
                          End If
                      Loop Until EN.Finished
                  Catch ex As Exception
                      hs.WriteLog("DumpZWaveDevices", ex.Message)
                  Finally
                      If (Not sw Is Nothing) Then sw.Close()
                  End Try
              End Sub
          68 Z-Wave Nodes, 175 Events, 359 Devices
            Cool, Thanks Rob!
            Don
                      Dim pk() As String
                      Dim s As Object
                      Dim x As Integer
                      Try
                          Do
                              dev = EN.GetNext
                                              sw.WriteLine(dev.Location(hs) & " - " & dev.Location2(hs) & " - " & dev.Name(hs) & ":  " & pk(x).ToString() & " = " & s.ToString())
                                          End If
                                      Next
                                  End If
                              End If
                      Finally
                      End Try
                  End Sub
              Awesome this worked great on my Linux HS3 box. Issue is that with hundreds of nodes, in some places such a Z-Wave logs, HS refers to devices by node number, and you can't easily see the node number in your device list, you'd have to open up each device to get that info. With your script I was quickly able to search the TXT file for the node number I was getting errors on and get its name so that I could then go to it in the device list.
                By the way, is there a way to modify the script to show list of device numbers instead, or even better both node and device numbers? I get errors like this in the log but have no idea which device is #580...
                Mar-11 10:51:00 PM Z-Wave Error Device 580 is being set to an invalid value: 0
                  I changed the code in my post above to add the device reference.
                  Try that and see if that works for you...
                    Awesome works great, thanks!!
