SAPI tags and string variables
    Is there a way to include SAPI tags within a string variable?
    I can create script line like,
    hs.Speak("some text" <SAPI tag> "some more text")
    I can also create a line like,
    hs.Speak(string)
    where 'string' is a string variable
    What I haven't been able to figure out is how to combine SAPI control tags and string variables in the hs.Speak function. Specifically, I'd like to include pauses in the string with <silence msec="1000"/>, for example. Is it possible? How?
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
    hs.Speak(string)
    The quickest and simplest is to use double quotes, because a single quote is what VB thinks is the end of a string that is why it will error...there may be some class out there that can add SAPI tags but if you are happy writing them out by hand then you would do;
    hs.Speak("some text <silence msec=""1000""/> some more text")
    VB.net will interpret the double quotes as the fact that you want to put a single quote in the string. They are not processed inside HS (done in the PC speech engine).
      Thank you. I'll give that a go.
      That did the trick.
