Well what i suddenly thought of is the following.
I am using a Vusolo 2 satellite receiver for my TV.
This has a web control function, i used Wireshark to capture some strings that i can use in homeseer for controlling almost everything.
This also has the function to display a message on the tv screen , it also has a question message where you have to respond with Yes or No and it gives the pressed value back to the browser.
So i thought, this would be great to display notices, for example device values when someone is calling the number.
Or when there is movement or well, whatever you want.
Also the option that it responds on YES or NO i can think of some nice things and further down the road i will think of different things for this solution
What i am trying is to get a device value in the url, but i am a bit stuck with this.
The url i need to trigger is this :
http://vusolo2/api/message?text=HERE COMES THE MESSAGE&type=2&timeout=2&_=1456770893382
So what i am trying to do , and not sure if this is possible is use a post command and then repace the HERE COMES THE MESSAGE with a value of a sensor.
I do see the message but it contains the device number, is this even possible to do this by calling a script ?
dim s const server_url = "http://vusolo2/api/message?text=$$DSR:150:&type=2&timeout=2&_=1456770893382" const headers="Content-Type: application/x-www-form-urlencoded" s = hs.URLAction(server_url, "POST", data, headers)
