Virtual Device Value After Restart
    Hi there,
    I am using a script to set values of virtual devices so the value can be changed by calling the script from HSTouch.
    It all works, but if i cycle the power off the HomeSeer PC values change back to where they were before.
    If I change values through the HomeSeer Web Control and cycle the power, new values remain changed.
    Does anyone know the reason for this difference?
    Here is the script i'm using:
    Sub SetVal(parm as object)
    Dim deviceName As String
    Dim valueStr As String
    Try
    hs.WriteLog("SetVal Debug", "Script Start")
    deviceName = parm(0)
    valueStr = parm(1)
    hs.WriteLog("SetVal Debug","parm(0)=" & deviceName)
    hs.WriteLog("SetVal Debug", "parm(1)=" & valueStr)
    hs.SetDeviceValueByName(deviceName,CLng(valueStr))
    hs.WriteLog("SetVal Debug", "Script Stop")
    Catch Ex As Exception
    hs.WriteLog("SetVal Error","Script exception is:" & Ex.Message)
    End Try
    End Sub
    Luka
    I haven't seen this issue with my scripts, but try adding a hs.SaveEventsDevices after changing the devices.
    Cheers
    Al
      Thanks for that. It worked.
      Sent from my SM-G900I using Tapatalk
