error running script, Help would be appreciated
    I am trying to run the script from this page:
    http://board.homeseer.com/showthread...light=unlocked
    Error I am getting:
    May-01 10:46:20 AM Error Running script(2) &C:/Program Files (x86)/HomeSeer HS3/scripts/doorlock.vb q1 test v1 Schlage 1, init error: Syntax error
    May-01 10:46:20 AM Event Running script statement immediately: &C:/Program Files (x86)/HomeSeer HS3/scripts/doorlock.vb q1 test v1 Schlage 1
    May-01 10:46:20 AM Event Event Trigger "Door Locks door script"
    May-01 10:46:20 AM Event Event Door Locks door script triggered by the event page 'Run' button.
    q1= node for lock
    test=name of lock
    v1-virtual device
    Schlage 1=type of device.
    It says to run it with calling method Main and pass parameters. Not sure what calling method Main means.
    Also tried to put this question in the above referenced linked but it said I didn't have rights.
    Any suggestions will be appreciated.
    Thanks...Sonny
    Hi Sonny, in the post with the script, there's a link to the discussion thread. You can post there. At first glance, it looks like you don't have commas between your parameters. If that doesn't resolve it, please post in the discussion thread. Also, you need to use the reference id's for those two devices, not the addresses.
    Cheers
    Al
