Virtual Device vs. Global Variable
  • waynehead99
    Wow thanks Jon. That clears it up for me. INI files are still over my head (except for updating the values in an already created one IE. your plugins).
    I like the idea of being able to store Arrays as I have a few scripts doing that already and that is where my experience and learning is right now with scripting in vb.net.
    Thanks again.
  • jon00
    Virtual devices
    Advantages:
    String/double integer is stored in the Homeseer database and not lost when rebooting.
    Can be read/saved by any script.
    Disadvantages:
    Can only store a single string and/or double Integer
    String will be visible on the web page against this virtual device.
    Global variables
    Advantages:
    Can hold any object (String,Integer,Array etc).
    Can be read/saved by any script once created.
    Unlimited number of variables can be created.
    Disadvantages:
    Variables are lost after each restart of Homeseer and have to be recreated.
    Can only store a single object per variable created.
    Ini files
    Advantages:
    Can hold any string.
    Globally available to be read/written from any script.
    Multiple storage areas available
    Data is never normally lost.
    Disadvantages:
    Can only store strings (but can be converted to Integers etc)
    May be slightly slower in read times than other methods
  • waynehead99
    started a topic Virtual Device vs. Global Variable
    I am a novice HS scripter and utilize Virtual Devices to hold data that I need for my scripts, but never actually use the virtual device for any other purpose.
    I guess my question is, what is the difference between using a Virtual Device vs a Global variable for this purpose. I know that global variables have to be defined each time HS is started up, but are they easier to use or should I just stick with virtual devices?
