need help with event script
    hi all,
    im building a script to make an event when running..
    but there is one thing i dont get , i get an error: ')' expected.
    this is the script:
    the line what gives the error is this one
    hs.AddDeviceActionToEvent(EvRef,hs.CAPIGetSingleControl(hs.G etDeviceRef("1623"),true,"on",false,true))
    i use tenscript aid. but where to put this line?
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(1623,True,"Off ",False,False))
    Sub CreateEvent(StartTime,StartDate,Delay,DeviceName)
    Dim EvRef As Integer
    Dim EvTime As Date
    dim CC as CAPIControl
    EvTime = "09:30"
    ' Create the Event
    EvRef = hs.NewEventEx("New Test Event","Test","")
    ' Set the time trigger
    hs.EventSetTimeTrigger(EvRef,EvTime)
    ' Add the device action "A13 On" which is the water heater
    ' Enable the Event
    hs.DeleteAfterTrigger_Set(EvRef)
    hs.EnableEventByRef(EvRef)
    End Sub
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    i soldev it already was a space in the script
      Does this work?
      hs.AddDeviceActionToEvent(EvRef,hs.CAPIGetSingleControl(1623,True,"Off",False,False))
        Thanks Adam ,
        thanks , i found my fault already , there was a blank space in my script , thats why it didn't trigger.
        do you know how i can add more actions to the script so i can make more ones like :
        1.delay
        2.event is manually triggered
        3.recurring
        im still learning scripting ,
        regards
        Originally posted by mrhappy View Post
        Does this work?
