Can script change Device Name, Location and Location2 Properties?
    Is it possible to change the Name and Location Properties of an existing Z-Wave Device via scripting? I'm still struggling to understand scripting and not sure if these Identity Properties described in the Device Class help documentation can be changed by script. I searched the boards for a while and cannot find examples of this.
    John
    Yes these are all parameters that can be edited by script - this is a script I use that removes all of the location two data in my system.
    Sub Main(ByVal Parm As Object)
        Try
            'run through the enumerator, remove the location two strings
            Dim dv As Scheduler.Classes.DeviceClass
            Dim EN As Scheduler.Classes.clsDeviceEnumeration
            EN = hs.GetDeviceEnumerator
            Do
                dv = EN.GetNext
                If dv Is Nothing Then Continue Do
                If dv.Location2(Nothing) <> Nothing Then
                    hs.writelog("Device Clear", "Device: " & dv.Name(Nothing) & " Has Location 2: " & dv.Location2(Nothing))
                    dv.Location2(hs) = Nothing
                End If
            Loop Until EN.Finished
        Catch ex As Exception : hs.writelog("Device Clear", "Exception: " & ex.message)
        End Try
    End Sub
