Help Please with first script
    I am trying to write my first script for my new HomeSeer Zee system using HSTouch Designer. I have the following command, which works just fine from the one line script utility on the ActionWhenPressed property.
    &hs.GetURL("192.168.1.231:80","/cgi_bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=*****&pwd=*****",TRUE,80)
    All I want to do is, do this with a script file, rather than the one line.
    So, I ssh'd onto my zee and found the /usr/local/HomeSeer/scripts directory.
    I then created a file called camctrl.vb and put the following into it.
    sub Main()
    dim page
    page = hs.GetURL("192.168.1.231:80","/cgi_bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=admin&pwd=890house",TRUE,80 )
    end sub
    I saved it, made it executable, etc. as follows:
    homeseer@HomeTrollerZeeS2 /usr/local/HomeSeer/scripts $ ls -al
    total 24
    drwxr-xr-x 2 homeseer root 4096 Jul 9 09:52 .
    drwxr-xr-x 19 homeseer root 4096 Jul 6 07:43 ..
    -rw-r--r-- 1 root root 655 Aug 25 2015 BBMessenger.vb
    -rwxr-xr-x 1 homeseer root 139 Jul 9 09:20 camctrl.vb
    -rw-r--r-- 1 homeseer root 228 Nov 21 2014 ShutDown.txt
    -rwxr-xr-x 1 homeseer root 934 Nov 21 2014 Startup.vb
    So then, in HS Touch Designer, I choose this script on the ActionWhenPressed property. I then save and deploy.
    Then button, which works just great without the script, now does nothing.
    What am I doing wrong?
    I've read so many posts, but find none that just walk me through a tutorial of doing what I'm trying to do --- which should be fairly simple.
    This shows up in the log so at least I know the script is being called:
    Running script camctrl.vb :Object reference not set to an instance of an object->Does entry point Main() exist in script? at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a () [0x00000] in :0
    Any help is APPRECIATED!!
    Thanks.
    Looks like you are mixing vbscript and vb.net syntax. Try:
    Sub Main(ByVal Parms As object)
    Dim page As String
    End Sub
    Cheers
    Al
      THANK YOU
      Dear Sparkman,
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      THANK YOU!!
      Oh yes, it worked!
