xml to device (how)
    xml to device (how)
    Hi all , how can i put this into a device
    lets say i want baby tv in an device (T1)
    how can i do that ?
    the url is this one
    http://192.168.0.35/web/subservices
    this is the response from above url
    <e2servicelist>
    <e2service>
    <e2servicereference>1:0:1:15BC:7ED:2:11A0000:0:0:0:</e2servicereference>
    <e2servicename>BabyTV</e2servicename>
    </e2service>
    </e2servicelist>
    i found a script on another topic but it doesnt write to the device
    i get an error
    PHP Code:
        Error 1    Running script C:\Program Files (x86)\HomeSeer HS3\scripts\skype_unknown.vb :Exception has been thrown by the target of an invocation.Conversion from string "t1" to type 'Integer' is not valid
    Sub Main(parms As Object)
    Dim Is_URL As String
    Dim Is_page As String
    Dim Is_start As String
    Dim Is_eind As String
    Dim Is_MyPos As Integer
    Dim Is_lengte As Integer
    Dim Is_script As String
    Dim debug As Integer
    Dim Is_DS As String
    debug = 0
    Is_script = "dbtest"
    Is_URL = "192.168.0.35"
    Is_page = "/web/subservices"
    Is_start = "<e2servicename>"
    Is_eind = "</e2servicename>"
    Is_DS = "T1"
    Is_page = hs.GetURL(Is_URL, Is_page, False, 80)
    If debug = 1 Then hs.SaveINISetting(Is_script, "XXXXXXXXfull page", Is_page, "my_gets.ini")
    Is_lengte = len(Is_start)
    If debug = 1 Then hs.writelog("Is_lengte:", Is_lengte)
    Is_MyPos = Instr(Is_page, Is_start)
    Is_MyPos = Is_MyPos + Is_lengte
    If debug = 1 Then hs.writelog("Is_MyPos:", Is_MyPos)
    Is_page = mid(Is_page, Is_MyPos)
    If debug = 1 Then hs.SaveINISetting(Is_script, "XXXXXXXXright page length", Is_MyPos, "my_gets.ini")
    If debug = 1 Then hs.SaveINISetting(Is_script, "XXXXXXXXright page", Is_page, "my_gets.ini")
    Is_MyPos = Instr(Is_Page, Is_eind) 'Returns the position of the first occurrence of one string within another.
    If debug = 1 Then hs.writelog("Is_MyPos end:", Is_MyPos)
    Is_page = mid(Is_page, 1, Is_MyPos - 1)
    If debug = 1 Then hs.SaveINISetting(Is_script, "XXXXXXXXfinal page right", Is_MyPos, "my_gets.ini")
    If debug = 1 Then hs.SaveINISetting(Is_script, "XXXXXXXXfinal page", Is_page, "my_gets.ini")
    If Is_page <> hs.DeviceString(Is_DS) Then
    hs.SetDeviceString(Is_DS, Is_page, True)
    End If
    end sub
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Look here for some similar ideas - http://forums.homeseer.com/showthread.php?t=177563
      hi Adam thanks for the reply ,
      i know that topic , but there is nothing i can use , if i could fix the script from above than its ok , but only 1 line is wrong and i cant get it to work .
      regards
        As you use my datascraper script already, why not just use that?
        Jon
          yeah right ! i check it out now
          do you think it works also ?
            I don't see why not:
            Pattern1=(?s)<e2servicename>(.*?)</e2servicename>
            Jon
              thanks JON
              it works , but my string returns as text (false) , can i say if its false then change to on ? like replace the word false to the word on and if it returns true replace to off ,can your script do that or can i better use easytrigger with it ?
                You could try:
                DeviceText1=[0] [replace "false","on"] [replace "true","off"]
                Jon
                  yes it works
                  many thanks !
                  You could try:
                    Remember this also works with the device value setting:
                    DeviceValue1=[0] [replace "false","1"] [replace "true","0"]
                    Jon
