Script should check for various conditions
    This is my first attempt with scripting, I have taken a script somebody did for me and I am trying to take it as a template for another script. I have changed a few things already but now am stuck.
    This is the script:
     Dim Temperature As Double
     Temperature = hs.DeviceValueEx(18)
     Dim Tempoutside As Double
     Tempoutside = hs.DeviceValueEx(14)
     Select Case Temperature
     Case < 20.4
     hs.TriggerEvent("AC off auto trigger")
     Case 22.0 To 23.5 and Tempoutside <18
     hs.TriggerEvent("open windows bedroom")
     Case > 23.5
     hs.TriggerEvent("close bedroom windows")
     End Select
     End Sub
    I know this is surely wrong but shows what I want to do:
    That's probably relatively easy to rectify.
    Now, the next condition I would like to incorporate I only want to trigger Case 22.0 To 23.5 and tempoutside <18 if bedroom window left and bedroom window right are closed.
    Also I only want
    Case > 23.5
    to trigger if bedroom window left and bedroom window right are open
    The first step, as you've done with Temperature, is to define variables for the state of the bedroom windows and set them equal to the value of the corresponding HS device. (I'll call them BRRight and BRLeft, and assume the device value is 100 if they are open.)
    I also believe you need to change 'Case' to 'Case Is' when you have an operator in the definition.
    To add a second condition to the Case statement, modify the action line with an If statement. So, try this:
    Case 22.0 To 23.5
       If Tempoutside < 18 Then hs.TriggerEvent("open windows bedroom")
    Case Is > 23.5
       If BRRight = 100 AND BRLeft = 100 Then hs.TriggerEvent("close bedroom windows")
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
      Ok thanks, I think I got it:
       Dim BedWindowR As Double
       BedWindowR = hs.DeviceValueEx(242)
       Dim BedWindowL As Double
       BedWindowL = hs.DeviceValueEx(252)
       Case < 20.4
       Case 22.0 To 23.5
       Case > 23.5
       If BedWindowR = 100 OR BedWindowL = 100 Then hs.TriggerEvent("close bedroom windows")
       End Select
       End Sub
      One more question, I have used OR in the last condition, as I want it to fire if either Bedroom Window is open, but also if both are open.
      Is OR going to be true if both are true ?
        Yes.
        Cheers
        Al
          I have added some hs.Speak actions (in blue)
                      Case 22.0 To 23.5
                         If Tempoutside < 18 Then hs.TriggerEvent("AC open bedroom windows")
                         hs.Speak("Bedroom temperature is " & hs.DeviceValueEx(18) & " Degrees")
                         hs.Speak(" and outside temperature is " & hs.DeviceValueEx(14) & " Degrees")
          I only want those spoken if Tempoutside < 18
          How do I do that, do I have to put 'If Tempoutside < 18 Then' in front of each 'hs.Speak' ?
          I have just tried that and it seems to work, but is that the best way ?
                        Case 22.0 To 23.5
                           End If
              That's better. Learnt a lot today... First day scripting, a lot more left to learn.
              Are there any example scripts, a user guide or something like that where I can try and read up ? I was looking at the scripts which were already there and try to understand what they were trying to do, that's where I got the hs.Speak action from...
                Mike. You are learning the way most of us do. There is some documentation out there, but really it's just taking what others have done and trial and error.
                I'm not a coder, but I am getting my way around VB.net on a basic level and it's opened up a lot of possibilities for me. Remember Google is your friend . And you have a lot of help here too.
                  Yes I am glad to have found a lot of help here.
                    Just a small observation:
                    If this is a single script, then you have obtained the device values at the beginning of the script and assigned them to variables, so there is no need to get them again and you could write as:
                    hs.Speak("Bedroom temperature is " & Temperature & " Degrees")
                    hs.Speak(" and outside temperature is " & Tempoutside & " Degrees")
                    Paul..
                      Ah great, I was wondering if I couldnt re-use the variables.
                        I just changed it, but I am getting this error now:
                        Jul-11 19:37:43
                        Error Compiling script C:\program files (x86)\homeseer hs3\scripts\bedroom window.vb: Statement cannot appear within a method body. End of method assumed. Jul-11 19:37:43 Error Compiling script C:\program files (x86)\homeseer hs3\scripts\bedroom window.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                        even changing it back to what it was before and I still get that error. Maybe because I copied and edited it in Word ?
                                      Case 22.0 To 23.5
                                         End If
                                      Case > 23.5
                                          If BedWindowR = 255 OR BedWindowL = 255 Then hs.TriggerEvent("AC close bedroom windows")
                                  End Select
                          If that's your whole script then its missing
                          End Sub
                          Try
                                        Case 22.0 To 23.5
                                           End If
                                        Case > 23.5
                                    End Select
                          End Sub
                          Paul..
                            Another suggestion for simplifying your scripts. You can combine this:
                            Into this:
                            Dim Temperature As Double = hs.DeviceValueEx(18)
                            Cheers
                            Al
                              It was the End Sub missing... ooops... must have lost it copying and pasting. And also now tidied up the script, looks a lot easier to read now. Thanks for the help and suggestions
                                        Dim Tempoutside As Double = hs.DeviceValueEx(14)
                                        Dim BedWindowR As Double = hs.DeviceValueEx(242)
                                        Dim BedWindowL As Double = hs.DeviceValueEx(252)
                                            Case 22.0 To 23.5
                                               End If
                                            Case > 23.5
                                 End Select
                              End Sub
