Logic questions
    Logic questions
    I have created this to load different heating schedules depending on outside and inside temperatures, I just wanted to make sure some things will work, for example
    Case 19 To 19.5
    If Tempoutside < 14 Then
    hs.TriggerEvent("Load Heating mornings and evenings")
    End If
    If Tempoutside > 14 Then
    hs.TriggerEvent("Load Heating mornings only")
    End If
    do I need the End If at all ? Can I have multiple If... for each case ? What happens if Tempoutside is exactly 14, which event will it trigger ?
    Just in case this is the full script (work in progress...)
    Dim Halltemp As Double = hs.DeviceValueEx(308)
    Dim Tempoutside As Double = hs.DeviceValueEx(14)
    Select Case Halltemp
    Case < 18.5
    If Tempoutside < 4 Then
    hs.TriggerEvent("Load Heating very cold")
    Case 18.5 To 19
    hs.TriggerEvent("Load Heating cold")
    Case 19 To 19.5
    End If
    End If
    Case > 19.5
    hs.TriggerEvent("Load Heating off")
    End Select
    End Sub
