Multiple if in a script ?
    Hi
    i created a script but nothing happens,
    if i use only one it works but i need more than 20
    i want like more if commands in my script,
    Sub Main(ByVal parm as Object)
    If (hs.devicevalue(2556) = 0) Then
    hs.TriggerEvent ("set 1")
    If (hs.devicevalue(2556) = 1) Then
    hs.TriggerEvent ("set 2")
    else
    hs.WriteLog("AV", "Device Not Selected")
    End If
    End If
    End Sub
    In my other script i have multiple IF statements and only 1 End IF
    like this but i cant get it to work , when i execute nothing happens no error or nothing
    If hs.DeviceStringByName ("test").contains ("test1") Then hs.blabla
    If hs.DeviceStringByName ("test").contains ("test2") Then hs.blabla
    If hs.DeviceStringByName ("test").contains ("test3") Then hs.blabla
    If hs.DeviceStringByName ("test").contains ("test4") Then hs.blabla
    If hs.DeviceStringByName ("test").contains ("test5") Then hs.blabla
    if hs.DeviceStringByName ("test").contains ("test6") Then hs.blabla
    End If
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    For that many conditions, it may be best to use the Select-Case statement: https://msdn.microsoft.com/en-us/library/cy37t14y.aspx.
    Cheers
    Al
      If you want to use If statements, structure it like this:
        If hs.devicevalue(2556) = 0 Then
        ElseIf hs.devicevalue(2556) = 1 Then
        Else
        End If
      End Sub
      Cheers
      Al
        Thanks Al
        this one works , but is it possible to use to trigger on specific device status text? like when 1=On
        Like this example but hs.devicestatus doesnt work..
        if hs.DeviceStatus ("2556").contains ("On") Then hs.TriggerEvent "test 1"
          Else
          End If
        End Sub
        Cheers
        Al
          Yes, it's possible, but there's no command called hs.devicestatus. Use CAPIGetStatus intead: http://homeseer.com/support/homeseer...igetstatus.htm.
          Cheers
          Al
            I have taken your script as a blueprint and tried to adapt it for my needs, but get errors:
            Jul-15 08:27:45 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\HeatingControl.vb: 'ElseIf' must be preceded by a matching 'If' or 'ElseIf'. Jul-15 08:27:45 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\HeatingControl.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
            If hs.devicevalue(224) = 14 Then hs.TriggerEvent ("Heat 14")
            ElseIf hs.devicevalue(224) = 18 Then hs.TriggerEvent ("Heat 18")
            ElseIf hs.devicevalue(224) = 20 Then hs.TriggerEvent ("Heat 20")
            ElseIf hs.devicevalue(224) = 18 Then hs.TriggerEvent ("Heat 21")
            End If
            End Sub
              End If
              End Sub
              It needs to be structured as I posted above. Anything after Then needs to be on a new line. For an If statement, if the action is on the same line, it considers it a complete If Then End If statement (the End If is implied at the end of the line), so when it sees the first ElseIf, it's not matched with your first If and that's why you get that error. See https://msdn.microsoft.com/en-us/library/752y8abs.aspx for details.
              Cheers
              Al
                I think that your syntax for devicevalue isn't correct
                This is how i do it
                 Imports System.Threading
                 Sub Main(byVal params As Object)
                   'Device indentifier-DeviceCode as found on properties screen of the device
                   Dim DEVICEID As String = TEST-X1"
                   Dim dvRef
                   'Get device reference
                   dvRef = hs.GetDeviceRef(DEVICEID)
                   Select Case hs.devicevalue(dvRef)
                     Case 18
                     Case 20
                     Case 21
                     Case Else 'Optional
                        ' Do something else when none found
                   End Select
                 End Sub
                  End Sub
                  does not work, I am still getting errors:
                  Jul-15 12:11:02 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\HeatingControl.vb: 'If' must end with a matching 'End If'. Jul-15 12:11:02 Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\HeatingControl.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
                  might try to modify the case one from AshaiRey for me
                  is that correct:
                  or should it be Dim DEVICEID As String = "TEST-X1"
                  also DEVICEID is 224, my device ref ?
                  Text-X1 is my device name, correct ?
                    I had a look at the vb manual, and changed my script. No errors any more, but I am not sure its triggering any event:
                    Jul-15 12:39:50 Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/HeatingControl.vb Jul-15 12:39:50 Event Event Trigger "HVAC Heating control trigger" Jul-15 12:39:50 Device Control Device: First Floor HVAC Heating Temp Control to 14 (0) by/from: CAPI Control Handler
                    this is my script now:
                    End If
                    End Sub
                    I found the problem, its all working now with the above script. The virtual device had value 0 as status 14, value 1 as status 18. Obviously that's why the script did not trigger anything. When I changed the value to status, so 14 to 14 etc it all started working.
                      End If
                      End Sub
                      Not sure if it was intentional but you have = 18 triggering 2 different events.
                      Probably won't have a lot of impact with a small script like this but I also prefer to either declare a variable and get the value from HS once:
                      Dim Value As Integer
                      Value = hs.devicevalue(224)
                      If Value = 18 ....
                      ElseIf Value = 20 ....
                      End If
                      or as previously posted
                      Select Case hs.devicevalue(224)
                      Case 18 ....
                      Case 20 ....
                      End Select
                      Paul..
                        I did not notice I have to check my script.
                        What is the advantage of declaring value rather than querying the device directly ?
                          Generally speaking, if you are re-using the same value multiple times within your script it will be more efficient both in terms of the amount of code you have to write and that you are only asking HS for the value once.
                          Code writing:
                          If for example at a later date you change the source device ref from 224 to 123, then you will only need to modify your script in one place. Not such an issue if (as in your example) you're only using it 3 times but it can become a pain in a large script where you are using the value many times.
                          General:
                          With a function like DeviceValue() it probably doesn't gain much but if you were using a more complex function that takes more processing, then it would be a waste of resources calling the function multiple times just to get the same result.
                          There are of course cases where you may need to call the function multiple times.
                          Dim MyValue as Integer = hs.DeviceValue(123)
                          If MyValue = 18 Then
                          hs.SetDeviceValueByRef(123, 10, True)
                          End If
                          If MyValue = 10 Then
                          End If
                          In the above, the second If would evaluate to false because it is using the value of "MyValue" which was obtained before it was modified with the first If.
                          In summary:
                          If you don't expect the value to change throughout the duration of your sub or function, then it is probably more efficient to call it once.
                          Paul..
                            Ok yes that makes perfect sense now.
                              Code writing:
                              General:
                              End If
                              End If
                              In summary:
                              Paul..
                              I want to extend this a bit further.
                              Imagion that the processing would be slow for this examples sake.
                              The script get the value at hs.devicevalue(224) and it is 18. the event will fire but in the meantime hs.devicevalue(224) becomes 20. What will happen then?
                              So it's better to get one reading and process the result of that reading.
                              Another point.
                              Magic numbers? In 6 months do you still know which which device is 224?
                              And you need to change that device to another device could you just change 224 to another number with or is that 224 number somewhere in your code just a value you test for?
                              Your life will be much easier if you get the habit to define these at the start of the program, before main() that is.
                              Something like this
                              const DEVICEID = 224 'Use descriptive names where you can
                              const MIDLEVEL = 18
                              cosnt HIGHLEVEL = 21
                              Constants are variables that are defined and can not be changed throughout your script when running. They are safe from unaspected altering. By using all caps for the name you will make it more recognizable for yourself that they are constants. VB isn't case sensative.
                              Use it like
                               int Value = hs.devicevalue(DEVICEID)
                               If Value = MIDLEVEL Then
                                ElseIf Value = HIGHLEVEL Then
                              End If
                              However even this little piece of code can be further improved.
