Device variable not working from script..
    This is a weird issue , normal iT always work, when i use the variable in my url to push to my Sattelite iT don't work
    But if i make an virtual device and set the string with easytrigger ($time) iT works when iT reads the code...
    Why does that happen?
    This is a part of the script (the action url)
    hs.urlaction("http://192.168.0.35/web/message?text= $time "&Volumestring &tester, "POST", "", "")
    Sended from far far away
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Anyone?
      Typically HomeSeer's replacement variables don't work in scripts. You'd have to use vb functions to retrieve the time and convert to a string.
      Cheers
      Al
        Hi Al,
        I did already try this:
        dim timer as string = hs.replacevariables ("$time")
        When i use iT in the url as &timer , the url works but no time in there
        I also want iT to use to read the $$Dsa:001: but don't know how to do that
        Regards
        Cheers
        Al
          What format does the time need to be in? To retrieve a device status in a script, use CAPIGetStatus: http://homeseer.com/support/homeseer...igetstatus.htm.
          Cheers
          Al
