How to set the value of a virtual switch ?
    I want to set the value of a virtual switch via a script. The virtual switch can have value 14,18,20 or 21.
    Sub Main(ByVal parm as Object)
    Dim Value As Integer
    Value = hs.devicevalue(227)
    'Heating main thermostat heat setpoint
    If Value = 14 Then
    set device 416 to 14
    ElseIf Value = 18 Then
    set device 416 to 18
    ElseIf Value = 20 Then
    set device 416 to 20
    ElseIf Value = 21 Then
    set device 416 to 21
    End If
    End Sub
    so I need the correct command for 'set device 416 to'
    You need to use hs.SetDeviceValueByRef(227,Value,True) where 227 is your Ref number..
    Robert
      This section of the help file may help you: http://homeseer.com/support/homeseer...ast_change.htm
      Cheers
      Al
