need some help with hs.SetDeviceString
    hi all ,
    im building a script but i always get an error
    Exception has been thrown by the target of an invocation.Conversion from string "Test-CUrrent" to type 'Integer' is not valid.
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Jon
      thanks jon ,
      yes ofcourse i forget the ByName hehe..
      i have quickly another last question , if i create a device by script , what do i need to put in there so that it wil be a status only device ?
      if i auto create now by script it stands on/of next to it
      like dvp.status_only device or something like that , i cant figure out if its possible
      regards and many thanks for the reply !
        i found it already , many thanks ,
          but jon there is actually an issue
          when an other plugin contains the same name it enters the string there
          my T.A is Test-CUrrent
          why does this work ?
          hs.setdevicevalue("Test-CUrrent",temperature) <--- works
            Because hs.setdevicevalue uses the name! To use a reference number, you need to use hs.setdevicevaluebyref.
            I agree this is wrong, however that's the way HST decided it should work.
            Jon
              hi jon thanks for the reply ,
              i understand now how it all works , i got it working now ,
              so i created a script i wil post it soon
              regards
