Im still learning scripting , so this is my 4th script
and i know jon00 has a wonderfull script called jon00 motherboard.
This is a cpu checker script.
he creates 2 devices (root) (Current) in room CPU TEMPERATURE.
and you have a config file, there you can set log= 1 or 0 zetten . this let you see the current temperature in the log with a message (hot)(warm)(cool) in color if you want.
INSTALLATION:
Just open the zip file and extract the 3 folders in the HS3 root directory
Make a recur event from 5/10 or more minutes and select the script , it wil create 2 devices , and you can see the temperature in the virtual device
its in celcius!
regards !
INSTALLATION:
its in celcius!
regards !
