Contacting HomeSeer This Week
See more
See less
devicelastchange question in a script
  • devicelastchange question in a script
    //ELAPSED TIME
    im building a very huge script and i need this option for my voice system if its possible..
    i have an script that gets the status of all my pir sensors .
    but i want that it get the last change also , and that it speaks the last change ...
    i already have it speaking the last change but it speaks wrong , it says 19 july 19:12:12 it says 19 days and 12 hours and 12 minutes...
    i want that it speaks like if the last change is 10 july 14:40:32 and the time is now 14:50:32 he must speak 10 minutes and 32 seconds ago.
    regards
    Last edited by Malosa; July 29th, 2016, 09:36 AM. Reason: FOrget something in the title
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.1.18 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Something to get you going:
    PHP Code:
    Sub Main(ByVal Parm As Object)
    Dim TN As Date DateTime.Now
        Dim LC
    As Date hs.devicelastchange("devicename")
    Dim TS As Timespan TN.Subtract(LC)
    Dim H As Integer TS.TotalHours
        Dim M
    As Integer TS.Minutes
        Dim S
    As Integer TS.Seconds
    If 0 Then
            hs
    .speak(" hours " " minutes and " " seconds ago")
        Else
            If
    0 Then
                hs
    .speak(" minutes and " " seconds ago")
            Else
    hs.speak(" seconds ago")
    End If
    End If
    End Sub
    Jon
      many many great thanks again JON!
      it works perfect , how can i add multiple device?
      what do i need to add to it , or do i need to change the code
      //edit , i found it out , i put after everything a 1 and so on.
      PHP Code:
          Dim LC
          Dim M
          Dim S
      If 0 Then
              hs
          Else
              If
      0 Then
                  hs
              Else
      End If
      End If
      End Sub
        You may be better leaving it as a subroutine and then calling it for each device name.
        Here is an example:
        PHP Code:
        Dim MyDeviceNames As Array = {"devicename1""devicename2""devicename3"}
            For
        Each DN As String In MyDeviceNames
                Announce
        (DN)
        Next
        End Sub
        Sub Announce
        (ByVal DeviceName As String)
            Dim LC
        As Date hs.devicelastchange(DeviceName)
            Dim M
            Dim S
        If 0 Then
                hs
            Else
                If
        0 Then
                    hs
                Else
        End If
        End If
        End Sub
        Jon
          thanks
          i got it
          many thanks !!!!
          Here is an example:
          PHP Code:
              For
                  Announce
          (DN)
          Next
          End Sub
          Sub Announce
              Dim LC
          As Date hs.devicelastchangeref(DeviceName)
              Dim M
              Dim S
          If 0 Then
                  hs
              Else
                  If
          0 Then
                      hs
                  Else
          End If
          End If
          End Sub
            jon
            how can i let it read the name instead of the reference? because i never remember the correct numbers, name is easy
            like PIR1,PIR2,PIR3
              I'm not quite sure I understand. I assume you have modified the code to announce the device name?
              I did change the hs.devicelastchangeref to hs.devicelastchange in my example.
              Jon
                hi jon ,
                like now i need to put the device ref in it , but if i change the code it still don't want to get my device name like (pir livingroom)i still need to put 2001 in there..
                i have it with the other scripts also
                regards
                  You can get the name, Location etc from the ref.
                  Here is an example:
                  PHP Code:
                  Dim dv As Scheduler.Classes.DeviceClass Nothing
                          Dim dvRef
                  As Integer 1234
                          Dim Location
                  As String ""
                  Dim Location2 As String ""
                  Dim Name As String ""
                  dv hs.GetDeviceByRef(dvRef)
                  Location dv.Location(hs)
                  Location2 dv.Location2(hs)
                  Name dv.Name(hs)
                  hs.writelog("Loc"Location)
                  hs.writelog("Loc2"Location2)
                  hs.Writelog("Name"Name)
                  End Sub
                  Jon
                    hi jon,
                    that example you give me works ,
                    i merged multiple scripts from the forum and edited some lines
                    but what did i do wrong here ,
                    i know this topic is getting different now but thats my last question
                    here i only can use the device ref but i want to use the names so later homeseer can speak the name of the pir instead of the ugly code , so normal it needs to work but i cant get it to work..
                    it counts the pir's that are online and disabled.. and also it says the status.
                    but when i want to add hs.speak (pir_name & " standby") nothing comes out only standby/
                    i know it looks like a mess but i need to clean it up later ,
                    dim array_pir() as string = {"2704","2698","2517"}
                    dim pirdisabled_count as integer = 0
                    dim pirenabled_count as integer = 0
                    dim pir_name as string = ""
                    dim pstr as string = ""
                    sub pir(ByVal Parms as Object)
                    Try
                    pirdisabled_count = 0
                    pirenabled_count = 0
                    pir_name = ""
                    pstr = ""
                     for each devp as string in array_pir
                        Select Case hs.DeviceValue(devp)
                          Case 0
                           pirenabled_count = pirenabled_count + 1
                         Case 1
                           hs.speak ("person detected in the **")
                         Case 11
                           pirdisabled_count = pirdisabled_count + 1
                         Case 15
                           hs.speak ("P I R in the ** is Enabled")
                         Case Else 'Optional
                            hs.speak ("P I R in the garden has an error please check the battery")
                       End Select
                    next
                        If pirdisabled_count > 0 then
                         hs.speak("found some")
                        Else
                            hs.speak("no count")
                        End If
                        hs.speak (pirdisabled_count, true, "$SONOS$TTS")
                        hs.writelog("Array", "enabled pir's: " & pirenabled_count)
                    	hs.writelog("Array", "disabled pir's: " & pirdisabled_count)
                     Catch ex As Exception
                    hs.WriteLog ("Array", "Error: " & ex.Message)
                    End Try
                    End Sub
                    output
                    Jul-31 15:36:35	 	Array	disabled pir's: 2
                    Jul-31 15:36:35	 	Array	enabled pir's: 1
                    Jul-31 15:36:35	 	TTS	Speak ($SONOS$TTS):2
                    Jul-31 15:36:35	 	TTS	Speak ():found some
                    Jul-31 15:36:35	 	TTS	Speak ():standby
                    this is my final question , im building and learning so its my first complex script for all my pir's
                      Does this work?:
                      PHP Code:
                          Dim array_pir() As String = {"2704""2698""2517"}
                      Dim pirdisabled_count As Integer 0
                          Dim pirenabled_count
                      As Integer 0
                          Dim pir_name
                      As String ""
                      Dim pstr As String ""
                          Sub pir
                      (ByVal Parms As Object)
                              Try
                      pirdisabled_count 0
                                  pirenabled_count
                      0
                                  pir_name
                      pstr ""
                      For Each devp As String In array_pir
                                      Select
                                          Case
                      0
                                              dv
                      hs.GetDeviceByRef(devp)
                      pir_name dv.Name(hs)
                      pirenabled_count pirenabled_count 1
                                              hs
                      .speak(pir_name "  standby")
                                          Case
                                              hs
                      .speak("person detected in the **")
                                          Case
                      11
                                              pirdisabled_count
                      pirdisabled_count 1
                      Case 15
                                              hs
                      .speak("P I R in the ** is Enabled")
                                          Case Else
                      'Optional
                                              hs.speak("P I R in the garden has an error please check the battery")
                                      End Select
                                  Next
                                  If pirdisabled_count > 0 Then
                                  Else
                                  End If
                                  hs.speak(pirdisabled_count, True, "$SONOS$TTS")
                      s" & pirenabled_count)
                                  hs.writelog("
                                  hs.WriteLog("Array", "Error: " & ex.Message)
                              End Try
                          End Sub
                      Jon
                        hi jon
                        many thanks for your time , it works !!
                        so i only have to copy these 2 lines in each case and it works
                        dv = hs.GetDeviceByRef(devp)
                        pir_name = dv.Name(hs)
                        regards and many thanks!!!
                        Does this work?:
                        PHP Code:
                        As Integer 0
                            Dim pir_name
                        As String ""
                            Sub pir
                                Try
                        pirdisabled_count 0
                                    pirenabled_count
                        0
                                    pir_name
                        pstr ""
                                        Select
                                            Case
                        0
                                                dv
                                                hs
                                            Case
                                                hs
                                            Case
                        11
                                                pirdisabled_count
                        pirdisabled_count 1
                        Case 15
                                                hs
                                            Case Else
                        'Optional
                                        End Select
                                    Next
                                    Else
                                    End If
                                    hs.writelog("
                                End Try
                            End Sub
                          You only need to enter it once if you put it outside the case statements i.e.:
                          PHP Code:
                              Sub pir(ByVal Parms As Object)
                                  Try
                          pirdisabled_count 0
                                      pirenabled_count
                          0
                                      pir_name
                          pstr ""
                                          dv
                                              Case
                          0
                                                  pirenabled_count
                          pirenabled_count 1
                                                  hs
                                              Case
                                                  hs
                                              Case
                          11
                                                  pirdisabled_count
                          pirdisabled_count 1
                          Case 15
                                                  hs
                                              Case Else
                          'Optional
                                          End Select
                                      Next
                                      Else
                                      End If
                                      hs.writelog("
                                  End Try
                              End Sub
                          Jon
                            thanks again ,
                            you right , im understanding now how everything works with array's and the rest.
                            you spare me a lot of time !
                            PHP Code:
                                    Try
                            pirdisabled_count 0
                                        pirenabled_count
                            0
                                        pir_name
                            pstr ""
                                            dv
                                                Case
                            0
                                                    pirenabled_count
                            pirenabled_count 1
                                                    hs
                                                Case
                                                    hs
                                                Case
                            11
                                                    pirdisabled_count
                            pirdisabled_count 1
                            Case 15
                                                    hs
                                                Case Else
                            'Optional
                                            End Select
                                        Next
                                        Else
                                        End If
                                        hs.writelog("
                                    End Try
                                End Sub
