How can I set a time + x
  • sparkman
    Looks great, I would do something like this:
    Sub Main(ByVal Parms As Object)
    	Dim Immersun As Double
    	Immersun = hs.DeviceValueEx(68)
    	Dim dateValue As Date = #21:55#
    	Dim Evref as Integer
    	dim Ok as Boolean
    	dim CC as CAPIControl
    	dim DeviceRef As Integer = 228  'deviceref of the device I want to control
    	Dim StopDateTime As Date
    	Select Case Immersun
    		Case < 1
    			StopDateTime = dateValue.AddMinutes(39)
    		Case 1.0 To 1.5
    			StopDateTime = dateValue.AddMinutes(30)
    		Case 1.5 To 2
    			StopDateTime = dateValue.AddMinutes(20)
    		Case 2.0 To 2.5
    			StopDateTime = dateValue.AddMinutes(15)
    		Case 2.5 To 3
    			StopDateTime = dateValue.AddMinutes(10)
    	End Select
    	If Immersun <= 3 Then
    		Evref = hs.NewEventEx("Testevent", "Test","")
    		' set the trigger time of the event
    		Ok = hs.EventSetTimeTrigger(Evref, CStr(StopDateTime))
    		' set the event to delete itself after it runs
    		hs.DeleteAfterTrigger_Set(Evref)
    		' add a device action to the event
    		CC = hs.CAPIGetSingleControlByUse(DeviceRef, ePairControlUse._Off)
    		hs.AddDeviceActionToEvent(Evref, CC)
    		hs.EnableEventByRef(Evref)
    	End If
    End Sub
    Cheers
    Al
  • mikee123
    Well thanks to your help I might have got it. Tested it and no errors in the log, but I will only see over the next few days if it does what I want. By just running the script, none of the cases is true, it creates an empty event with just if the time is 21.55 (as delay is 0)
    So last thing I need to do is enter a case > 3, which then jumps to the end, so does not create the event. How do I do that jump or end the script before the event creation ?
    This is the (nearly) finished script
            dim Evref as Integer
     dim Delay as Integer
     dim Ok as Boolean
    Dim StopDateTime As Date = dateValue.AddMinutes(Delay)
                 Case < 1
                 Case 1.0 To 1.5
                Case 1.5 To 2
               Case 2.0 To 2.5
               Case 2.5 To 3
             End Select
        End Sub
  • sparkman
    Originally posted by mikee123 View Post
    This:
    will set my desired device to off in the created event ? So if I wanted 'on' I change ePairControlUse._Off to ePairControlUse._On ?
    if I understand it right my script should work. will give it a try later
    I do not use Event types (yet) for my events so I deleted that
    Correct. You'll likely need to specify "" for the Event Type rather than just deleting it as the help file does not indicate it's an optional parameter. As for your script, I would use the Case section to just set the Delay value and then have the event portion after the case section rather than copying it multiple times. Also, see my previous post about the Dim statement and that you can only have one per variable.
    Cheers
    Al
  • mikee123
    Ok I think I understand it. This is what I've done
     dim Ok as Boolean
     dim DeviceRef As Integer = 1234  'deviceref of the device I want to control
                 Case < 1
                 dim Delay as Integer = 15
                  Dim newDateValue As Date = dateValue.AddMinutes(15)
             Evref = hs.NewEventEx("Testevent", "Test")
     Ok = hs.EventSetTimeTrigger(Evref, CStr(newDateValue))
                 Case 1.0 To 1.5
                  dim Delay as Integer = 20
             End Select
        End Sub
    This:
  • sparkman
                 Case < 1
                 Case 1.0 To 1.5
                   Dim newDateValue As Date = dateValue.AddMinutes(20)
    Note that you can't "Dim" the same variable multiple times. You'd have to do it like this:
                 Case < 1
                  newDateValue = dateValue.AddMinutes(15)
                 Case 1.0 To 1.5
                  newDateValue = dateValue.AddMinutes(20)
  • sparkman
    What you want to do then is have the script create an event that runs at the required time and then deletes itself. I do something similar in one of my scripts. Here's a code snippet that creates an event to turn a device off:
    	dim Ok as Boolean
    	Dim StopDateTime As Date = DateTime.Now.AddMinutes(Delay)
    	Evref = hs.NewEventEx("Event Name", "Event Group", "Event Type")
  • mikee123
    This is the sort of script I had in mind, with the line below just trying to show what I am trying to achieve
    at time Date hs.TriggerEvent("x1") or hs.setdevicevalue(123) to 0
                 Case < 1
                 Case 1.0 To 1.5
                 Case > 1.5 to 2
                    Dim newDateValue As Date = dateValue.AddMinutes(25)
                 Case > 2 to 2.5
                    Dim newDateValue As Date = dateValue.AddMinutes(30)
                 Case > 2.5 to 3
                    Dim newDateValue As Date = dateValue.AddMinutes(35)
             End Select
         End Sub
  • mikee123
    Yes, a bit cryptic. Something like this should work:
    Now that is what you would hope to find in a manual, that makes it perfectly clear.
    Can I then use 'Date' either in a script to trigger a setdevicevalue action at the time 'Date', or if that's not possible use 'Date' in an event, to trigger an event at time 'Date'
  • sparkman
  • mikee123
    Ok trying to read that I think that's written in Chinese. .. lol
    I think I might get it will have to have another look and try to understand it. Why can't they give simple examples... its so hard to understand.
    Anyway I noticed this isn't all I need to solve my problem, as I need the resulting time of that calculation (time + x) needs to be used to trigger a event or a device action. So I could either try to trigger an event from the script, or keep it all in a script and: at time + x setdevicevalue. ..
    I think I would prefer to keep it all in a script then it's all in one place. Unless it's going to be even more complicated than setting the time...
  • sparkman
    You can use the vb.net AddMinutes method: https://msdn.microsoft.com/en-us/lib...v=vs.110).aspx.
    Cheers
    Al
  • mikee123
    started a topic How can I set a time + x
    I want to use time + x minutes in a script. I have various cases, and depending on case I want to add a different amount of minutes to a set time. So in my first case it would be
    21:55 + 30 minutes
    Is that doable ? I know how to do the case, it's just the time + x which I don't know how to do
