How can I set a time + x
    I want to use time + x minutes in a script. I have various cases, and depending on case I want to add a different amount of minutes to a set time. So in my first case it would be
    21:55 + 30 minutes
    Is that doable ? I know how to do the case, it's just the time + x which I don't know how to do
    You can use the vb.net AddMinutes method: https://msdn.microsoft.com/en-us/lib...v=vs.110).aspx.
    Cheers
    Al
      Ok trying to read that I think that's written in Chinese. .. lol
      I think I might get it will have to have another look and try to understand it. Why can't they give simple examples... its so hard to understand.
      Anyway I noticed this isn't all I need to solve my problem, as I need the resulting time of that calculation (time + x) needs to be used to trigger a event or a device action. So I could either try to trigger an event from the script, or keep it all in a script and: at time + x setdevicevalue. ..
      I think I would prefer to keep it all in a script then it's all in one place. Unless it's going to be even more complicated than setting the time...
        Yes, a bit cryptic. Something like this should work:
        Dim dateValue As Date = #21:55#
        Dim newDateValue As Date = dateValue.AddMinutes(15)
          Now that is what you would hope to find in a manual, that makes it perfectly clear.
          Can I then use 'Date' either in a script to trigger a setdevicevalue action at the time 'Date', or if that's not possible use 'Date' in an event, to trigger an event at time 'Date'
            This is the sort of script I had in mind, with the line below just trying to show what I am trying to achieve
            at time Date hs.TriggerEvent("x1") or hs.setdevicevalue(123) to 0
            Sub Main(ByVal Parms As Object)
                     Dim Immersun As Double
                    Immersun = hs.DeviceValueEx(68)
                     Select Case Immersun
                         Case < 1
                         Case 1.0 To 1.5
                           Dim newDateValue As Date = dateValue.AddMinutes(20)
                         Case > 1.5 to 2
                            Dim newDateValue As Date = dateValue.AddMinutes(25)
                         Case > 2 to 2.5
                            Dim newDateValue As Date = dateValue.AddMinutes(30)
                         Case > 2.5 to 3
                            Dim newDateValue As Date = dateValue.AddMinutes(35)
                     End Select
                 End Sub
              What you want to do then is have the script create an event that runs at the required time and then deletes itself. I do something similar in one of my scripts. Here's a code snippet that creates an event to turn a device off:
              	dim Evref as Integer
              	dim Delay as Integer = 15
              	dim Ok as Boolean
              	dim CC as CAPIControl
              	dim DeviceRef As Integer = 1234
              	Dim StopDateTime As Date = DateTime.Now.AddMinutes(Delay)
              	Evref = hs.NewEventEx("Event Name", "Event Group", "Event Type")
              	' set the trigger time of the event
              	Ok = hs.EventSetTimeTrigger(Evref, CStr(StopDateTime))
              	' set the event to delete itself after it runs
              	hs.DeleteAfterTrigger_Set(Evref)
              	' add a device action to the event
              	CC = hs.CAPIGetSingleControlByUse(DeviceRef, ePairControlUse._Off)
              	hs.AddDeviceActionToEvent(Evref, CC)
              	hs.EnableEventByRef(Evref)
                Originally posted by mikee123 View Post
                             Case < 1
                             Case 1.0 To 1.5
                Note that you can't "Dim" the same variable multiple times. You'd have to do it like this:
                             Case < 1
                              newDateValue = dateValue.AddMinutes(15)
                             Case 1.0 To 1.5
                              newDateValue = dateValue.AddMinutes(20)
                  Ok I think I understand it. This is what I've done
                   dim Ok as Boolean
                   dim DeviceRef As Integer = 1234  'deviceref of the device I want to control
                               Case < 1
                           Evref = hs.NewEventEx("Testevent", "Test")
                   Ok = hs.EventSetTimeTrigger(Evref, CStr(newDateValue))
                               Case 1.0 To 1.5
                                dim Delay as Integer = 20
                           End Select
                      End Sub
                  This:
                  will set my desired device to off in the created event ? So if I wanted 'on' I change ePairControlUse._Off to ePairControlUse._On ?
                  if I understand it right my script should work. will give it a try later
                  I do not use Event types (yet) for my events so I deleted that
                    This:
                    Correct. You'll likely need to specify "" for the Event Type rather than just deleting it as the help file does not indicate it's an optional parameter. As for your script, I would use the Case section to just set the Delay value and then have the event portion after the case section rather than copying it multiple times. Also, see my previous post about the Dim statement and that you can only have one per variable.
                    Cheers
                    Al
                      Well thanks to your help I might have got it. Tested it and no errors in the log, but I will only see over the next few days if it does what I want. By just running the script, none of the cases is true, it creates an empty event with just if the time is 21.55 (as delay is 0)
                      So last thing I need to do is enter a case > 3, which then jumps to the end, so does not create the event. How do I do that jump or end the script before the event creation ?
                      This is the (nearly) finished script
                       dim Ok as Boolean
                       dim DeviceRef As Integer = 228  'deviceref of the device I want to control
                      Dim StopDateTime As Date = dateValue.AddMinutes(Delay)
                                   Case < 1
                                   StopDateTime = dateValue.AddMinutes(39)
                                   Case 1.0 To 1.5
                                  StopDateTime = dateValue.AddMinutes(30)
                                  Case 1.5 To 2
                                  StopDateTime = dateValue.AddMinutes(20)
                                 Case 2.0 To 2.5
                                  StopDateTime = dateValue.AddMinutes(15)
                                 Case 2.5 To 3
                                  StopDateTime = dateValue.AddMinutes(10)
                               End Select
                               Evref = hs.NewEventEx("Testevent", "Test","")
                          End Sub
                        Looks great, I would do something like this:
                        	Dim Evref as Integer
                        	dim Ok as Boolean
                        		Case < 1
                        		Case 1.0 To 1.5
                        		Case 1.5 To 2
                        		Case 2.0 To 2.5
                        		Case 2.5 To 3
                        	End Select
                        	If Immersun <= 3 Then
                        	End If
                        End Sub
                        Cheers
                        Al
