Problem with a count line
    Hi all
    this is a piece of a script , and i dont know why he doesnt speak the last value from this line: If error_count = 0 Then
    there is no error , so normal he would need to trigger...
    PHP Code:
    pirdisabled_count
                pirenabled_count
                error_count
    0
                pir_name
    pstr ""
    For Each devp As String In array_pir
                   dv
    hs.GetDeviceByRef(devp)
    location dv.location(hs)
    pir_name dv.Name(hs)
    Select Case hs.DeviceValue(devp
                        Case
                            pirenabled_count
    pirenabled_count
                            hs
    .speak(pir_name "  at the  " &   location "  is standby"
                        Case
                            hs
    .speak("person detected in the " location
                        Case
    11
                            pirdisabled_count
    pirdisabled_count
                            hs
    .speak(pir_name "  at the  " &   location "  is Disabled"
                        Case
    15
                            hs
    .speak("P I R in the ** is Enabled"
                        Case
    9
                            pirdisabled_count
    pirdisabled_count
                            hs
    .speak(" battery ")
                        Case Else
    error_count error_count 1
                            hs
    .speak (pir_name "  at the" location " has an error")
    End Select
                Next
                hs
    .speak ("There are  " pirenabled_count " Sensors Enabled ")
    hs.speak ("And " pirdisabled_count " Sensors Disabled ")
                If
    pirEnabled_count 0 Then
                    hs
    .writelog("Array""enabled pir's: " pirenabled_count)
                If
    pirdisabled_count 0 Then
                    hs
    .writelog("Array""disabled pir's: " pirdisabled_count)
                If
    error_count 0 Then
                    hs
    .writelog("Array""Errors: " error_count)
    hs.speak ("no Errors found")
                Else
    End If
    End If
    End if
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Originally posted by Malosa View Post
    Hi all
    PHP Code:
    pirdisabled_count
                pirenabled_count
                error_count
    0
                pir_name
    pstr ""
                   dv
                        Case
                            pirenabled_count
    pirenabled_count
                            hs
                        Case
                            hs
                        Case
    11
                            pirdisabled_count
    pirdisabled_count
                            hs
                        Case
    15
                            hs
                        Case
    9
                            pirdisabled_count
    pirdisabled_count
                            hs
    .speak(" battery ")
                        Case Else
    'Optional
                            error_count = error_count + 1
                            hs.speak (pir_name & "  at the" & location & " has an error")
                    End Select
                Next
                hs.speak ("There are  " & pirenabled_count & " Sensors Enabled ")
                hs.speak ("And " & pirdisabled_count & " Sensors Disabled ")
                If pirEnabled_count > 0 Then
                    hs.writelog("Array", "enabled pir'
    s" & pirenabled_count)
                If pirdisabled_count > 0 Then
                    hs.writelog("
    Array", "disabled pir's: " & pirdisabled_count)
                    hs.writelog("Array", "Errors: " & error_count)
                Else
                End If
                End If
                End if
    regards
    You're missing a single quote on the line:
    Case Else 'Optional
    Should be 'Optional'
    Look at the color coding. You can see it's trying to show you were it's incorrect.
    Z
      Case Else needs to be there , if the device is a different state as the case ,
      the red color is because i use the ' i deleted it , check now again , because your quote is not valid anymore
      'Optional
      Z
        Sorry wasn't clear:
        Case Else 'Optional'
        Z
          hi vasrc
          i think you understand me wrong
          that is not the problem 'Optional' is just a text
          Case Else just works normal , and all the events under it , except this one : If error_count = 0 Then
          Sorry wasn't clear:
          Z
            hi vasrc
            Then the listing you posted had a typo on the "Case Else 'Optional " line
            Check to make sure error_count IS equal to zero before your If check by putting some hs.writelog statements to see where it's changing.
            I'm guessing in the Case Else statement
            Z
              ok i changed the error_count to 1 and let it make an error
              still not speaking , but i declared it before the IF
              looks like it can't count
              look it doesnt even trigger the writelog events....
              Aug-02 15:57:04	 	TTS	Speak ():And 2 Sensors Disabled
              Aug-02 15:57:04	 	TTS	Speak ():There are 0 Sensors Enabled
              Aug-02 15:57:04	 	TTS	Speak ():Motion sensor 3 at the Livingroom is Disabled
              Aug-02 15:57:04	 	TTS	Speak ():Motion sensor 1 Battery at the Garden has an error
              Aug-02 15:57:04	 	TTS	Speak ():Motion sensor 1 at the Garden is Disabled
              Z
                Like now i got it working when there is nor error , it says no error and triggers also the logs ..
                but when there is an error (from case else ) , he doesnt speak anymore and no logs...
                Like if a device value has something else than 0,1,11,15,9 than it goes to Case else , after that nothing triggers anymore ,
                here the new code
                PHP Code:
                Sub pir(ByVal Parms As Object
                        Try
                pirdisabled_count
                            pirenabled_count
                            error_count
                0
                            pir_name
                pstr ""
                               dv
                                    Case
                                        pirenabled_count
                pirenabled_count
                                        hs
                                    Case
                                        hs
                                    Case
                11
                                        pirdisabled_count
                pirdisabled_count
                                        hs
                                    Case
                15
                                        hs
                                    Case
                9
                                        hs
                .speak(" battery ")
                                    Case Else
                                        hs
                End Select
                            Next
                If pirEnabled_count 0 Then
                                hs
                            If
                                hs
                            If
                error_count 0 Then
                                hs
                            Else
                End If
                End If
                End if
                '=======================================LOG COUNTS============================================================
                hs.writelog("Array""enabled pir's: " pirenabled_count)
                'hs.writelog("Array", "disabled pir's" & pirdisabled_count)
                            'hs.writelog("
                Array", "Errors" & error_count)
                '======================================SPEECH COUNTS==========================================================
                            hs.speak ("
                            hs.speak ("
                            hs.speak ("
                no Errors found")
                            If error_count > 0 Then
                            hs.speak (error_count & "
                errors found ")
                '===================================SPEECH CLIENT SELECT======================================================
                            'speak trough selected speaker client string
                            'hs.speak(pirdisabled_count & "
                lol", True, "$SONOS$TTS")
                            end if
                            end if
                            end if
                            end if
                        Catch ex As Exception
                            hs.WriteLog("
                Array", "Error" & ex.Message)
                        End Try
                    End Sub
                output without error in a device just all in case and it counts the errors , there are 0 :
                Aug-02 16:23:19	 	TTS	Speak ():no Errors found
                Aug-02 16:23:19	 	TTS	Speak ():And 2 Sensors Disabled
                Aug-02 16:23:19	 	TTS	Speak ():There are 1 Sensors Enabled
                Aug-02 16:23:19	 	Array	Errors: 0
                Aug-02 16:23:19	 	Array	disabled pir's: 2
                Aug-02 16:23:19	 	Array	enabled pir's: 1
                Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 3 at the Livingroom is Disabled
                Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 2 at the Garage is standby
                Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 1 at the Garden is Disabled
                output with an error in a device , using Case else :
                Aug-02 16:22:22	 	TTS	Speak ():Motion sensor 3 at the Livingroom is Disabled
                Aug-02 16:22:22	 	TTS	Speak ():Motion sensor 1 Battery at the Garden has an error
                Aug-02 16:22:22	 	TTS	Speak ():Motion sensor 1 at the Garden is Disabled
                  Not sure I understand. What you listed for:
                  Output Case Else
                  Looks correct? It shows that an error occurred (Motion Sensor 1 Battery at the Garden) and it logged it. You're saying it's not speaking is all?
                  Z
                    yes look at the output of the error it only have the speak line for what device is enabled or disabled or an error ,
                    everything what comes next to it doesnt work...
                    but if it doesnt use the else (so no error) everything works
                    this line is from the case else
                    Output Case Else
                    Z
                      Is it getting past the Next statement or exiting before that?
                      Uncomment the duplicate Array logging and see if you can tell where it's exiting the script.
                      No other errors listed in the HS3 log?
                      Z
                        check my post at 8 , there is the detailed log
                        Its getting the statement after the next , but if an device has no error it works also and its after the next
                        no errors in my log , just not triggering behind this
                        PHP Code:
                                Try
                        pirdisabled_count
                                    pirenabled_count
                                    error_count
                        0
                                    pir_name
                        pstr ""
                                       dv
                                            Case
                                                pirenabled_count
                        pirenabled_count
                                                hs
                                            Case
                                                hs
                                            Case
                        11
                                                pirdisabled_count
                        pirdisabled_count
                                                hs
                                            Case
                        15
                                                hs
                                            Case
                        9
                                                hs
                        .speak(" battery ")
                                            Case Else
                                                hs
                        End Select
                          It's getting past the NEXT when it has an Error, but it may not for the NO error condition (I don't see any Array logs shown for NO error? It should have an Array No Errors at least). Try uncommenting the LOG COUNTS to see what they are.
                          Just checking to make sure it's actually executing the code and not exiting silently.
                          Z
                            here at post 8:
                            this is with no error
                            The error is an device with value 75 just for testing
                            Z
                            Z
                              Right, problem is WITH an error
                              Too many phone calls here....
                              Your log shows you get a Speak when you have an Error:
                              Is that not working or it's logging but not actually saying anything? You're using what to Speak (ie TTS?)
                              Or is the logging in the IF statements that's not working?
                              Z
