Problem with a count line
    #16
    if i execute the script normal , and add my device codes in there
    there is case , 0,1,11,9, else
    Normal my devices are on 0=standby and 11=disabled
    i get this the normal log and works
    Aug-02 16:23:19	 	TTS	Speak ():no Errors found
    Aug-02 16:23:19	 	TTS	Speak ():And 2 Sensors Disabled
    Aug-02 16:23:19	 	TTS	Speak ():There are 1 Sensors Enabled
    Aug-02 16:23:19	 	Array	Errors: 0
    Aug-02 16:23:19	 	Array	disabled pir's: 2
    Aug-02 16:23:19	 	Array	enabled pir's: 1
    Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 3 at the Livingroom is Disabled
    Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 2 at the Garage is standby
    Aug-02 16:23:19	 	TTS	Speak ():Motion sensor 1 at the Garden is Disabled
    if i change 1 device code to an device that has a value of 75 and run the script , i get this log
    so it triggers normal the speach , but no the array log and the other speech what needs to come after...
    PHP Code:
    Aug-02 16:22:22         TTS    Speak ():Motion sensor 3 at the Livingroom is Disabled
    Aug
    -02 16:22:22         TTS    Speak ():Motion sensor 1 Battery at the Garden has an error
    Aug
    -02 16:22:22         TTS    Speak ():Motion sensor 1 at the Garden is Disabled
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      #17
      I'll bet if you uncomment the LOG COUNTS, that will tell you if it's the IF statements that are not firing, or it's not actually getting to them.
      Change your If's to:
      If pirEnabled_count > 0 Then
      hs.writelog("Array", "enabled pir's: " & pirenabled_count)
      End If
      If pirdisabled_count > 0 Then
      hs.writelog("Array", "disabled pir's: " & pirdisabled_count)
      End If
      If error_count = 0 Then
      hs.writelog("Array", "Errors: " & error_count)
      End If
      Z
        #18
        this is very strange , you solved my problem !!
        why is the problem End If
        so what does it matter if i put the End If somewhere else..
        really weird
        but many thanks for your time, and sorry for disturbing
        many thanks!
        End If
        End If
        End If
        Z
          #19
          End If tells each "IF, Else IF or Else when to stop looking. If you don't stop it, it may not process the "IF" below it because the initial IF was true..
          Z
            #20
            ok , i remind it now
            yes its new for me because i started scripting a few weeks ago
            now i learned a new thing.
            many thanks!!
            Z
              #21
              As an FYI, if you only have one line for each IF, then you can simplify to:
              If pirEnabled_count > 0 Then hs.writelog("Array", "enabled pir's: " & pirenabled_count)
              If pirdisabled_count > 0 Then hs.writelog("Array", "disabled pir's: " & pirdisabled_count)
              If error_count = 0 Then hs.writelog("Array", "Errors: " & error_count)
              Each line is considered a complete If/END IF statement even though the END IF is not there.
              Cheers
              Al
                #22
                Try using indentation and spacing to help "see" your code better. If you had done this with your original code it would have looked like this:
                PHP Code:
                If pirEnabled_count 0 Then
                   hs
                .writelog("Array""enabled pir's: " pirenabled_count)
                   If
                pirdisabled_count 0 Then
                        hs
                .writelog("Array""disabled pir's: " pirdisabled_count)
                        If
                error_count 0 Then
                            hs
                .writelog("Array""Errors: " error_count)
                        Else
                End If
                End If
                End if
                You can now see why it might not get to the internal IF statements.
                Z
                  #23
                  Hi AL
                  yeah already tried that but doesnt trigger the counts also...
                  Cheers
                  Al
                  hi vasrc
                  i did this and its working also , its clear visable for me
                  PHP Code:
                  '======================================SPEECH COUNTS==========================================================
                              hs.speak ("There are  " & pirenabled_count & " Sensors Enabled ")
                              End If
                              hs.speak ("And " & pirdisabled_count & " Sensors Disabled ")
                              End If
                              hs.speak ("no Errors found")
                              End If
                              If error_count > 0 Then
                              hs.speak ("And " & error_count & " Errors")
                              End If
                  ===================================SPEECH CLIENT SELECT======================================================
                  PHP Code:
                     hs
                     If
                          hs
                          If
                  error_count 0 Then
                              hs
                          Else
                  End If
                  End If
                  End if
                  Z
