Need help with a parm in a script
    Hi all ,
    i created a huge script , so when i insert in parm PIR it triggers the pir part , and when i set Smoke it triggers the smoke part , but how can i set it up to trigger them both or seperate.. just whenever i want?
    but cant use it separate anymore , it only listens to both together... anyone a solution?
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    i use it for this ,
    after this :
    i put this line :
    if parms="pir" then
    and the END IF at the end of the first script line.
    i just need to know how i can use both names together when i call the script ,and separate.
    if i put it like this nothing happens
    if parms="pir" then
    if parms="pir,smoke" then
      Try changing:
      to
      Sub Main(ByVal Parms As String)
      Also, see the last post in this thread for a script that deals with a variable number of parameters: http://board.homeseer.com/showthread.php?t=172875.
      Cheers
      Al
        Hi Al
        thanks for the reply
        it still don't work .
        im doing like this :
        if parms="pir" then
        TRY
        REST SCRIPT 1 HERE
        END TRY
        END IF
        TRY
        if parms="smoke" then
        REST SCRIPT 2 HERE
        END TRY
        END IF
        END SUB
        In the parameters i can put pir or smoke , it works , but not both..
        Originally posted by sparkman View Post
        Try changing:
        to
        Cheers
        Al
          Try using "contains" instead of equal. You can find some examples here:
          http://vb.net-informations.com/strin...g_Contains.htm
          Fred
          HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
            all thanks for the reply , i found it out already
            if parms="pir" or parms="pir,smoke" then
            this solves the problem
              Here is an example:
              PHP Code:
              Sub Main(ByVal parms As String)
                  If
              parms.Contains("pir"Then
              'REST SCRIPT 1 HERE
                  End If
                  If parms.Contains("smoke") Then
              REST SCRIPT 2 HERE
                  End
              If
              End Sub
              Remember, what you enter for the parms string will be case sensitive so 'pir' will work but 'PIR' would not.
              To get around that, you can do the following:
              PHP Code:
                  If
              parms.ToLower.Contains("pir"Then
              'REST SCRIPT 1 HERE
                  End If
                  If parms.ToLower.Contains("smoke") Then
              REST SCRIPT 2 HERE
                  End
              If
              End Sub
              Now the parms can be set to 'pir' 'PIR' 'pIr' etc.
              Jon
                Hi Jon,
                many thanks again,
                i never knew about this one .ToLower.Contains
                That also solves my other scripts aswell !!!
                thanks !
                Originally posted by jon00 View Post
                Here is an example:
                PHP Code:
                    If
                'REST SCRIPT 1 HERE
                    End If
                REST SCRIPT 2 HERE
                    End
                If
                End Sub
                PHP Code:
                    If
                'REST SCRIPT 1 HERE
                    End If
                REST SCRIPT 2 HERE
                    End
                If
                End Sub
                  The other nice thing about "contains" is that it doesn't care in what order the parms are passed. So in your case, any of the following would work the same:
                  pir, smoke
                  smoke, pir
                  pir smoke
                  "pir" "smoke"
                  "pir smoke"
                  Etc. etc.
                  Fred
