Script to take pictures and email them
    I have tried doing this with events but it doesn't work properly, and I'd like to know how I could do this with a script instead
    I want netcam to take x amount of pictures 1 second apart and email each one as an attachment
    does the plugin netcam do that?
    or try ultranetcam from ultrajones
    i use pushbullet , it sends me in a message
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      It doesnt have to be netcam, I dont know if it can be done with netcam. As long as I can send my pics by email, and do that all in a script I dont care how
        ah ok
        check here ,
        http://board.homeseer.com/showthread.php?t=149450
        regards
          Thats seems part of it, sending the pics. How do I take them via a script, ?
            Assuming a snapshot image can be obtained from your camera(s) then what you want to achieve is partially possible with built in HS3 scripting functions.
            You can grab the images and save to file using hs.GetURLImage.
            One caveat is that the HS3 SendEmail function (I believe) only allows a single file attachment so you will either have to zip up the images and send the zip or create your own send email function that will allow multiple attachments.
            Either way, its not a 5 minute job but as before, I'm happy to help you if required.
            Paul..
              i did a search for you on another forum , and good news , there is the script what you are looking for
              http://www.domoticaforum.eu/viewtopic.php?f=14&t=6069
              regards
