is this possible in a script ?
    I have a script that calls all the pir's in an array like this example
    dim array_pir() as string = {"2512","2513","2517","2518"}
    It checks all the devices with the case.. like this :
    Select Case hs.DeviceValue(devp)
    Case 0
    Case 4
    If S < 30  Then
    hs.speak("Person detected at the " & location)
    End If
    Case 11
    Case 15
    Case 75
    Case Else 'Optional
    Here is the thing , how can i let it run a specific event on the device that it matches.
    like case 4 is for a person is detected if its lower than 30 seconds ago, i want to run an event that matches that device ... the event is a timer ...
    if there are more triggers on that case it must be trigger also the event it matches the device.. so i can trigger seperate timer events trough script
    or can i do something with hs.RegisterStatusChangeCB (i really dont know how this works)
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    or is this also possible
    pir_name = dv.Name(hs)
    hs.TriggerEvent(pir_name)
    But i also cant get it to work , i created an event with the exact same name as the pir device , but doesnt trigger the event...
      anyone an idea ?
