Status/modifying timer CAPI
    Hello
    Can I modifying timer status from CAPI, start, stop, set value?
    I only find command in API manual for reset and read value.
    Or is't undocumented commands for this?
    Brg
    Findus
    No, there are no script commands, however, you can do this from an event.
    68 Z-Wave Nodes, 175 Events, 359 Devices
      Interesting.
      You mean I should trigger an event and where it is "hard coded" what to do with the timer?
      Can I pass arguments to the event, such as set timer to 34 seconds?
        Originally posted by Findus View Post
        Interesting.
        In an event, you can set the timer value to start, but you're right - it will be hard-coded and not 'dynamic'
