hs.getinisetting issue
    SOlved!
    Hi all
    i have build many scripts that contain hs.getinisetting
    but here is a problem with reading it .
    it needs to read the array from an ini file
    in the ini file it looks like this
    PHP Code:
    [XML]
    Devices={"2212"
    this is in the very beginning ,
    Const INI_FILE As String = "PIR_TEST.ini"
    dim devices as string = hs.GetINISetting("xml","Devices","", INI_FILE)
    dim array_pir() as string = devices
    THis gives this error :
    PHP Code:
    Value of type 'String' cannot be converted to '1-dimensional array of String'
    it looks like he doesnt accept devices as an array string , how can i solve it ?
    Regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    i did also try this Inside the sub main :
    PHP Code:
    dim devices as string hs.GetINISetting("xml","Devices",""INI_FILE)
    hs.speak (devices)
    dim array_pir() as string = {devices
    with this ini file :
    PHP Code:
    [XML]
    Devices="2212","2212","2216"
    i get this :
    PHP Code:
    Aug-18 13:57:13         Array    ErrorConversion from string "2212","2212","2216" to type 'Integer' is not valid.
    Aug-18 13:57:08         TTS    Speak ():2212","2212","2216
    Looks like it can't get the " from the ini file .....
    i really out of options here , dont know what to do , i know its possible
      You should be able to use:
      Devices=2212,2212,2216
      Then just convert it to an array using Split:
      Dim Devices As String = hs.GetINISetting("xml","Devices","", INI_FILE)
      Dim x As Integer
      Dim ary() As String = Devices.Split(",")
      For x = 0 To ary.Length - 1
      hs.Speak(ary(x)
      Next
      68 Z-Wave Nodes, 175 Events, 359 Devices
        thanks ,
        i still get this error
        Aug-18 15:24:16 Array Error: Object reference not set to an instance of an object.
        normal my script needs to read the array like this when u pt it manual in there :
        dim array_pir() as string = {"2623","2622","2626"}
        but i want to use a ini instead
        the hs.speak was only for testing the output
        Dim x As Integer
        hs.Speak(ary(x)
        Next
          The use of the curly braces is for hard-coding the array list in the code.
          The method I posted was for a dynamic way of passing in a list of values.
          For testing purposes, you can use:
          Dim x As Integer
          ''Dim ary() As String = Devices.Split(",")
          dim ary() as string = {"1234","5678"}
          hs.Speak(ary(x)
          Next
            ok , i want to use the dynamic way but it doesnt work
            i always get an error
            i show you what kind of script im using :
            PHP Code:
            Dim array_pir() As String = {"2704""2698""2517"
            Dim pirdisabled_count As Integer
                Dim pirenabled_count
            As Integer
                Dim pir_name
            As String ""
            Dim pstr As String ""
            Dim dv As Scheduler.Classes.DeviceClass Nothing
                Sub pir
            (ByVal Parms As Object
                    Try
            pirdisabled_count
                        pirenabled_count
                        pir_name
            pstr ""
            For Each devp As String In array_pir
                            Select
            Case hs.DeviceValue(devp
                                Case
                                    dv
            hs.GetDeviceByRef(devp
            pir_name dv.Name(hs
            pirenabled_count pirenabled_count
                                    hs
            .speak(pir_name "  standby"
                                Case
                                    hs
            .speak("person detected in the **"
                                Case
            11
                                    pirdisabled_count
            pirdisabled_count
            Case 15
                                    hs
            .speak("P I R in the ** is Enabled"
                                Case Else
            'Optional
                                    hs.speak("P I R in the garden has an error please check the battery")
                            End Select
                        Next
                        If pirdisabled_count > 0 Then
                            hs.speak("found some")
                        Else
                            hs.speak("no count")
                        End If
                        hs.speak(pirdisabled_count, True, "$SONOS$TTS")
                        hs.writelog("Array", "enabled pir'
            s" & pirenabled_count)
                        hs.writelog("
            Array", "disabled pir's: " & pirdisabled_count)
                    Catch ex As Exception
                        hs.WriteLog("Array", "Error: " & ex.Message)
                    End Try
                End Sub
            this line :
            Dim array_pir() As String = {"2704", "2698", "2517"}
            i want that it reads from the ini file instead of hardcoding it
            it still gives me errors
            PHP Code:
            Aug-18 15:24:16    Array    ErrorObject reference not set to an instance of an object
            Dim x As Integer
            hs.Speak(ary(x)
            Next
              Change your script to this:
              PHP Code:
              Sub pir(ByVal Parms As Object)
              Dim pirdisabled_count As Integer 0
              As Integer 0
                      Dim pir_name
              As String ""
                      Dim array_pir
              () As String hs.GetINISetting("xml""Devices"""INI_FILE).split(",")
                      Try
              pirdisabled_count 0
                          pirenabled_count
              0
                          pir_name
              pstr ""
                              Select
              Case hs.DeviceValue(devp)
                                  Case
              0
                                      dv
              hs.GetDeviceByRef(devp)
              pir_name dv.Name(hs)
              pirenabled_count pirenabled_count 1
                                      hs
              .speak(pir_name "  standby")
                                  Case
                                      hs
              .speak("person detected in the **")
                                  Case
              11
                                      pirdisabled_count
              pirdisabled_count 1
              Case 15
                                      hs
              .speak("P I R in the ** is Enabled")
                                  Case Else
              'Optional
                              End Select
                          Next
                          Else
                          End If
                          hs.writelog("
                      End Try
                  End Sub
              In your INI file, enter the value like this:
                very good !
                send you a pm , that one works on this script , but this script is old , i send you the correct script in a pm
                regards
                //sended right now
                  Solved
                  thanks rmasonjr!
                    No problem - anytime!
