hs.getinisetting issue
  • rmasonjr
    No problem - anytime!
  • Malosa
    Solved
    thanks rmasonjr!
  • Malosa
    very good !
    send you a pm , that one works on this script , but this script is old , i send you the correct script in a pm
    regards
    //sended right now
  • rmasonjr
    Change your script to this:
    PHP Code:
    Sub pir(ByVal Parms As Object)
    Dim pirdisabled_count As Integer 0
            Dim pirenabled_count
    As Integer 0
            Dim pir_name
    As String ""
    Dim pstr As String ""
    Dim dv As Scheduler.Classes.DeviceClass Nothing
            Dim array_pir
    () As String hs.GetINISetting("xml""Devices"""INI_FILE).split(",")
            Try
    pirdisabled_count 0
                pirenabled_count
    0
                pir_name
    pstr ""
    For Each devp As String In array_pir
                    Select
    Case hs.DeviceValue(devp)
                        Case
    0
                            dv
    hs.GetDeviceByRef(devp)
    pir_name dv.Name(hs)
    pirenabled_count pirenabled_count 1
                            hs
    .speak(pir_name "  standby")
                        Case
                            hs
    .speak("person detected in the **")
                        Case
    11
                            pirdisabled_count
    pirdisabled_count 1
    Case 15
                            hs
    .speak("P I R in the ** is Enabled")
                        Case Else
    'Optional
                            hs.speak("P I R in the garden has an error please check the battery")
                    End Select
                Next
                If pirdisabled_count > 0 Then
                    hs.speak("found some")
                Else
                    hs.speak("no count")
                End If
                hs.speak(pirdisabled_count, True, "$SONOS$TTS")
                hs.writelog("Array", "enabled pir'
    s" & pirenabled_count)
                hs.writelog("
    Array", "disabled pir's: " & pirdisabled_count)
            Catch ex As Exception
                hs.WriteLog("Array", "Error: " & ex.Message)
            End Try
        End Sub
    In your INI file, enter the value like this:
    Devices=2212,2212,2216
  • Malosa
    ok , i want to use the dynamic way but it doesnt work
    i always get an error
    i show you what kind of script im using :
    PHP Code:
    Dim array_pir() As String = {"2704""2698""2517"
    As Integer
        Dim pir_name
    As String ""
        Sub pir
            Try
    pirdisabled_count
                pirenabled_count
                pir_name
    pstr ""
                    Select
                        Case
                            dv
    pir_name dv.Name(hs
                            hs
                        Case
                            hs
                        Case
    11
                            pirdisabled_count
    pirdisabled_count
    Case 15
                            hs
                        Case Else
    'Optional
                    End Select
                Next
                Else
                End If
                hs.writelog("
            End Try
        End Sub
    this line :
    Dim array_pir() As String = {"2704", "2698", "2517"}
    i want that it reads from the ini file instead of hardcoding it
    it still gives me errors
    PHP Code:
    Aug-18 15:24:16    Array    ErrorObject reference not set to an instance of an object
    Originally posted by rmasonjr View Post
    The use of the curly braces is for hard-coding the array list in the code.
    The method I posted was for a dynamic way of passing in a list of values.
    For testing purposes, you can use:
    Dim Devices As String = hs.GetINISetting("xml","Devices","", INI_FILE)
    Dim x As Integer
    ''Dim ary() As String = Devices.Split(",")
    dim ary() as string = {"1234","5678"}
    For x = 0 To ary.Length - 1
    hs.Speak(ary(x)
    Next
  • rmasonjr
    Dim x As Integer
    hs.Speak(ary(x)
    Next
  • Malosa
    thanks ,
    i still get this error
    Aug-18 15:24:16 Array Error: Object reference not set to an instance of an object.
    normal my script needs to read the array like this when u pt it manual in there :
    dim array_pir() as string = {"2623","2622","2626"}
    but i want to use a ini instead
    the hs.speak was only for testing the output
    You should be able to use:
    Then just convert it to an array using Split:
    Dim x As Integer
    hs.Speak(ary(x)
    Next
  • rmasonjr
    Dim x As Integer
    hs.Speak(ary(x)
    Next
  • Malosa
    i did also try this Inside the sub main :
    PHP Code:
    dim devices as string hs.GetINISetting("xml","Devices",""INI_FILE)
    hs.speak (devices)
    dim array_pir() as string = {devices
    with this ini file :
    PHP Code:
    [XML]
    Devices="2212","2212","2216"
    i get this :
    PHP Code:
    Aug-18 13:57:13         Array    ErrorConversion from string "2212","2212","2216" to type 'Integer' is not valid.
    Aug-18 13:57:08         TTS    Speak ():2212","2212","2216
    Looks like it can't get the " from the ini file .....
    i really out of options here , dont know what to do , i know its possible
  • Malosa
    started a topic hs.getinisetting issue
    SOlved!
    Hi all
    i have build many scripts that contain hs.getinisetting
    but here is a problem with reading it .
    it needs to read the array from an ini file
    in the ini file it looks like this
    PHP Code:
    [XML]
    Devices={"2212"
    this is in the very beginning ,
    Const INI_FILE As String = "PIR_TEST.ini"
    dim devices as string = hs.GetINISetting("xml","Devices","", INI_FILE)
    dim array_pir() as string = devices
    THis gives this error :
    PHP Code:
    Value of type 'String' cannot be converted to '1-dimensional array of String'
    it looks like he doesnt accept devices as an array string , how can i solve it ?
    Regards
