how to read a csv file
    SOLVED!!
    Does anyone know how to let homeseer read a csv file from C:/ ?
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    There are quite a few examples of this here if you search, there are also plenty of options available for .net reading a CSV file (you have the option to read as data or if it is a very simple file you can just split a single line on the comma).
      Hi Adam
      thanks , i found one
      but i need your help , i build one and it works , but here is the thing.
      When i get a new value in the csv file i want that it shows only the new value not the past value , how to do that ?
      because when it updates it shows ony the first entry and also change the (lastchange) so it multi trigger an event...
      ( i use a ini file to configure from thats why i put this here Dim FileName As string = path )
      its for my anpr
      this is the csv , but the last entry i don;t need , but it works like this
      23/08/2017,02:44,"PT-FK-41","PT-FK-41.jpg"
      Dim str As String
      		Dim SplitStr() As String
      		str = My.Computer.FileSystem.ReadAllText(FileName)
      		SplitStr = Split(str, ",")
      		hs.writelog("0", SplitStr(0)) 'Date
      		Ref = hs.GetDeviceRef("ANPR-Date")
              hs.SetDeviceString(ref, SplitStr(0), True)
      		hs.writelog("1", SplitStr(1)) 'Time
      		Ref = hs.GetDeviceRef("ANPR-Time")
              hs.SetDeviceString(ref, SplitStr(1), True)
      		hs.writelog("2", SplitStr(2)) 'Plates
      		Ref = hs.GetDeviceRef("ANPR-Plates")
              hs.SetDeviceString(ref, SplitStr(2), True)
        Either test whether the string is different in a nested if...then loop or try something like this (not sure if it will work);
        hs.SetDeviceString(ref, SplitStr(2), IIf(hs.devicestring(ref) = SplitStr(2), False, True))
          Hi Adam , thanks for the reply
          with that string nothing changes ,
          Here is the code again then without everythig added, i just keep it simple.
          	        Dim str As String
          		str = My.Computer.FileSystem.ReadAllText ("C:/test.csv")
          		End Sub
          Output in log is this
          Aug-28 13:38:06	 	2	"PT-FK-41"
          Aug-28 13:38:06	 	1	20:44
          Aug-28 13:38:06	 	0	23/08/2016
          Inifile is this
          23/08/2016,20:44,"PT-FK-41","PT-FK-41.jpg"
          23/08/2017,02:44,"PT-FK-41","PT-FK-42.jpg"
          The second row is the last entry , i just want it to read te last new row.
          regards
            There may be better ways of doing this but I have in the past split on the new line (Chr(0) I think), then for each new line I would then split each line on the comma. Depending on the amount of data depends on whether or not this is a great method because as I say there are options in .net to read this in as data and instead query it like you would a database.
              hi Adam
              i made this one but ,it shows the first line , then the second line
              what do i need to change that it only shows the last line of the file , because if i expand this script and let it write to a virtual device , t will constantly change till he reached the end of the file..
              this script is in .VB it was in .txt i converted it.
              Dim fso, file, filename, data, r, cmd, path, arrSplitData
              Path = "C:\test.csv"
              fso = CreateObject("Scripting.FileSystemObject")
              file = fso.OpenTextFile(Path, 1, True)
              do while file.AtEndOfStream <> True
              r = file.ReadLine
              arrSplitData = split(r,",")
              hs.writelog("0", arrSplitData(0))
              hs.writelog("0", arrSplitData(1))
              hs.writelog("0", arrSplitData(2))
              Loop
              file.Close
              end sub
                i got it ,
                this must be under file.close and it works
                but there is one problem left , if the last entry doesnt change how can i let it not change the last change at the device? when the script has run
