.Contains only triggers at value's not text
    SOLVED!!!
    Hi all ,
    sorry again for another question but i cant fix it , i searched all over the internet and forums for this issue ..
    I have this :
    Plates is a part of an array in a ini file so it reads the text i put in there
    ref2= a virtual device
    devp= the data i put in the ini when it match..
    For Each devp As String In plates
    		Ref = hs.GetDeviceRef("ANPR-Plates")
    		Ref2 = hs.DeviceString(ReF)
    		hs.writelog("Virtual device value", ref2)
    		hs.writelog("Data in the ini", devp)
    		If ref2.Contains (devp) Then hs.speak ("Plates, ini file working")
    i get this output and that works ,
    Aug-29 17:02:13	 	TTS	Speak ():Plates, ini file working
    Aug-29 17:02:13	 	Data in the ini	PT-FK-99
    Aug-29 17:02:13	 	Virtual device value	"PT-FK-99"
    This one hs the problem, this one checks an other ini file for a match and triggers also a voice event.
    so it compare's the output of the ref2 and matches it with another ini file at split arrSplitData2(0)
    		hs.writelog("Data in Compare", arrSplitData2(0))
    		If arrSplitData2(0).ToLower.Contains (ref2) then hs.speak (" TIme, Match found in compare File") '<
    I get this result , it reads ok it should trigger but it doesnt...
    the data is fine.. even if i use the capitals nothing triggers , but if its a value it triggers normal...
    Aug-29 17:02:13	 	Data in Compare	pt-fk-99
    Now if i let it read a virtual device with a value in it like a time value it works :
    Ref = hs.GetDeviceRef("ANPR-Time")
    		hs.writelog("Data in Compare", arrSplitData2(1))
    		If arrSplitData2(1).ToLower.Contains (ref2) then
    		 hs.speak (" TIme, Match found in compare File") '<--- this line is the compare line ref2=the virtual arrsplitdata2 = path4
    		end if
    Aug-29 17:22:22	 	TTS	Speak ():TIme, Match found in compare File
    Aug-29 17:22:22	 	Data in Compare	02:44
    Aug-29 17:22:22	 	Virtual device value	02:44
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
