Comparing files and date
    SOLVED!!
    Hi all ,
    i dont know how i can do this :
    i want to compare the data from a csv to a string of a virtual device
    If i use this line it works with the entered info in the ini file :
    If ref2.ToLower.Contains (devp.ToLower.replace("-","")) Then hs.speak ("Plates, ini file working")
    but if i want it to use wuth the csv file it doesnt work , but the log shows the correct data at both ...why doesnt it trigger ?
    If arrSplitData2(0).ToUpper.Contains (ref2) then hs.writelog("Compare","Match Found!   " & arrSplitData2(0))
    i have solved already the compare date with this :
    Dim StartDate As Date = obj.Item("vervaldatum").ToString 'Start Date
    		Dim CompareDate As Date = Now.Date 'Todays Date
    		Dim result as integer = Datetime.Compare(startdate, Comparedate)
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Solved it , it was a comma at wrong place
