FileSystemWatcher script (need help)
    Hi all
    i have a FileSystemWatcher script that i want to port to homeseer
    i try some things but i get alway an error identifier expected..
    this is the script.
    hope someone can help me
    PHP Code:
    Imports System.IO
    Imports System
    .Diagnostics
    dim watchfolder
    As FileSystemWatcher
        Sub Main
    (ByVal Parms As Object)
    watchfolder = New System.IO.FileSystemWatcher()
    watchfolder.Path "C:\test\"
        watchfolder.NotifyFilter = IO.NotifyFilters.DirectoryName
        watchfolder.NotifyFilter = watchfolder.NotifyFilter Or _
                                   IO.NotifyFilters.FileName
                                   IO.NotifyFilters.Attributes
        AddHandler watchfolder.Changed, AddressOf logchange
        AddHandler watchfolder.Created, AddressOf logchange
        AddHandler watchfolder.Deleted, AddressOf logchange
        AddHandler watchfolder.Renamed, AddressOf logrename
        watchfolder.EnableRaisingEvents = True
    End Sub
     Private Sub logchange(ByVal source As Object, ByVal e As  _
                            System.IO.FileSystemEventArgs)
            If e.ChangeType = IO.WatcherChangeTypes.Changed Then
                hs.writelog("
    File " & e.FullPath & _
    has been modified" & vbCrLf)
            End If
            If e.ChangeType = IO.WatcherChangeTypes.Created Then
                hs.writelog("
    File" & e.FullPath & _" has been created" & vbCrLf)
            End If
            If e.ChangeType = IO.WatcherChangeTypes.Deleted Then
                hs.writelog("
    has been deleted" & vbCrLf)
            End If
        End Sub
        Public Sub logrename(ByVal source As Object, ByVal e As  _
                                System.IO.RenamedEventArgs)
            hs.writelog("
    File" & e.OldName & _
    has been renamed to " & e.Name & vbCrLf)
    End Sub
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Why not use Jon00's plug-in?
    http://board.homeseer.com/showthread.php?t=169604
      i didn't know Jon had one .
      but i wanted to implement it into my script , thats why i wanted to port that script
      thanks for the reply
        You cannot really use FileWatcher to monitor a file in a script. If you did, the script would have to run continuously and never terminate.
        It would be very bad practice to do so in Homeseer.
        Jon
          hi jon
          no not in this script what im building.
          it uses a second one to use as a recurring ,
          otherwise indeed homeseer would use a lot of cpu .
          but ill write in my doc that they can download your script to use it also so no problem
          regards,
