Contacting HomeSeer This Week
See more
See less
FileSystemWatcher script (need help)
  • Malosa
    hi jon
    no not in this script what im building.
    it uses a second one to use as a recurring ,
    otherwise indeed homeseer would use a lot of cpu .
    but ill write in my doc that they can download your script to use it also so no problem
    regards,
  • jon00
    You cannot really use FileWatcher to monitor a file in a script. If you did, the script would have to run continuously and never terminate.
    It would be very bad practice to do so in Homeseer.
  • Malosa
    i didn't know Jon had one .
    but i wanted to implement it into my script , thats why i wanted to port that script
    thanks for the reply
    Originally posted by Uncle Michael View Post
  • Uncle Michael
    Why not use Jon00's plug-in?
    http://board.homeseer.com/showthread.php?t=169604
  • Malosa
    started a topic FileSystemWatcher script (need help)
    Hi all
    i have a FileSystemWatcher script that i want to port to homeseer
    i try some things but i get alway an error identifier expected..
    this is the script.
    hope someone can help me
    PHP Code:
    Imports System.IO
    Imports System
    .Diagnostics
    dim watchfolder
    As FileSystemWatcher
        Sub Main
    (ByVal Parms As Object)
    watchfolder = New System.IO.FileSystemWatcher()
    watchfolder.Path "C:\test\"
        watchfolder.NotifyFilter = IO.NotifyFilters.DirectoryName
        watchfolder.NotifyFilter = watchfolder.NotifyFilter Or _
                                   IO.NotifyFilters.FileName
                                   IO.NotifyFilters.Attributes
        AddHandler watchfolder.Changed, AddressOf logchange
        AddHandler watchfolder.Created, AddressOf logchange
        AddHandler watchfolder.Deleted, AddressOf logchange
        AddHandler watchfolder.Renamed, AddressOf logrename
        watchfolder.EnableRaisingEvents = True
    End Sub
     Private Sub logchange(ByVal source As Object, ByVal e As  _
                            System.IO.FileSystemEventArgs)
            If e.ChangeType = IO.WatcherChangeTypes.Changed Then
                hs.writelog("
    File " & e.FullPath & _
    has been modified" & vbCrLf)
            End If
            If e.ChangeType = IO.WatcherChangeTypes.Created Then
                hs.writelog("
    File" & e.FullPath & _" has been created" & vbCrLf)
            End If
            If e.ChangeType = IO.WatcherChangeTypes.Deleted Then
                hs.writelog("
    has been deleted" & vbCrLf)
            End If
        End Sub
        Public Sub logrename(ByVal source As Object, ByVal e As  _
                                System.IO.RenamedEventArgs)
            hs.writelog("
    File" & e.OldName & _
    has been renamed to " & e.Name & vbCrLf)
    End Sub
