Script Error 1 Exception has been thrown by the target of an invocation
  • SgtBilko
    Well spotted.
    I didn't need MsgBox at all, it was part of my debugging process. Deleted the line.... no error message.
    Thank you very much
    Ian
  • mrhappy
    Just having a quick visual scan through the only thing that looks unusual is your call to MsgBox(RssString), that to me is the only thing that looks vaguely like it could cause an error in the forms namespace - from your path to the script do you run on Linux? I'm not sure how Linux plays with forms, if you need the message box are you able to call Messagebox.Show instead?
  • SgtBilko
    I don't mind sharing. It isn't very pretty code as I knocked it up quickly, I should go back and add error traps etc. Any way here it is.
    Public Sub Main(ByVal Parms As Object)
    Dim RssString = ParseRssFile() 'get the RSS details as string
    Dim SMarker = InStr(RssString, "day=0'>") + 7 'find the start fo today's name
    Dim EMarker = InStr(SMarker, RssString, ":") 'finf the end of it
    Dim Length = EMarker - SMarker ' find the legth of the text
    Dim strDay0 = Trim(Mid(RssString, SMarker, Length)) ' make that strDay0 e.g. Suunday
    MakeDevice("Day0", strDay0, strDay0, False)
    SMarker = EMarker + 1 'move the start of search to the begining of the strForecast for that day
    EMarker = InStr(EMarker, RssString, ",") ' and the end marker to the next comma
    Length = EMarker - SMarker ' get the length of the text
    Dim strForecast0 = Trim(Mid(RssString, SMarker, Length)) ' make that the strForecast0 e.g. Light Cloud
    MakeDevice("Forecast0", strForecast0, strForecast0, True)
    'Find Maxuimum Temperture - if it exists (once past heat of day RSS feed misses it out on todays weather.
    Dim ShortRSS = Left(RssString, 200)
    Dim intMaxTemp0
    Dim strMaxTemp0 As String
    If InStr(SMarker, ShortRSS, "Maximum Temperature:") = 0 Then
    intMaxTemp0 = "-"
    strMaxTemp0 = "-"
    Else
    SMarker = InStr(EMarker, RssString, "Maximum Temperature:") + 20
    EMarker = InStr(SMarker, RssString, "C") - 1 '-1 becuase don't want degrees symbol
    intMaxTemp0 = Trim(Mid(RssString, SMarker, Length))
    strMaxTemp0 = Trim(Mid(RssString, SMarker, Length + 2))
    End If
    MakeDevice("MaxTemp0", intMaxTemp0, strMaxTemp0, False)
    SMarker = InStr(EMarker, RssString, "Minimum Temperature:") + 20
    Dim intMinTemp0 = Trim(Mid(RssString, SMarker, Length))
    Dim strMinTemp0 As String = Trim(Mid(RssString, SMarker, Length + 2))
    MakeDevice("MinTemp0", intMinTemp0, strMinTemp0, False)
    SMarker = InStr(EMarker, RssString, "Wind Speed:") + 11
    EMarker = InStr(SMarker, RssString, "mph")
    Dim intWindSpeed0 = Trim(Mid(RssString, SMarker, Length))
    Dim strWindSpeed0 As String = Trim(Mid(RssString, SMarker, Length + 3))
    MakeDevice("WindSpeed0", intWindSpeed0, strWindSpeed0, False)
    'DAY1
    SMarker = InStr(EMarker, RssString, "day=1'>") + 7
    Dim strDay1 = Trim(Mid(RssString, SMarker, Length))
    MakeDevice("Day1", strDay1, strDay1, False)
    Dim strForecast1 = Trim(Mid(RssString, SMarker, Length))
    MakeDevice("Forecast1", strForecast1, strForecast1, True)
    Dim intMaxTemp1 = Trim(Mid(RssString, SMarker, Length))
    Dim strMaxTemp1 = Trim(Mid(RssString, SMarker, Length + 2))
    MakeDevice("MaxTemp1", intMaxTemp1, strMaxTemp1, False)
    Dim intMinTemp1 = Trim(Mid(RssString, SMarker, Length))
    Dim strMinTemp1 As String = Trim(Mid(RssString, SMarker, Length + 2))
    MakeDevice("MinTemp1", intMinTemp1, strMinTemp1, False)
    Dim intWindSpeed1 = Trim(Mid(RssString, SMarker, Length))
    Dim strWindSpeed1 = Trim(Mid(RssString, SMarker, Length + 3))
    MakeDevice("WindSpeed1", intWindSpeed1, strWindSpeed1, False)
    'strDay 2
    SMarker = InStr(EMarker, RssString, "day=2'>") + 7
    Dim strDay2 = Trim(Mid(RssString, SMarker, Length))
    MakeDevice("Day2", strDay2, strDay2, False)
    Dim strForecast2 = Trim(Mid(RssString, SMarker, Length))
    MakeDevice("Forecast2", strForecast2, strForecast2, True)
    Dim intMaxTemp2 = Trim(Mid(RssString, SMarker, Length))
    Dim strMaxTemp2 As String = Trim(Mid(RssString, SMarker, Length + 2))
    MakeDevice("MaxTemp2", intMaxTemp2, strMaxTemp2, False)
    Dim intMinTemp2 = Trim(Mid(RssString, SMarker, Length))
    Dim strMinTemp2 = Trim(Mid(RssString, SMarker, Length + 2))
    MakeDevice("MinTemp2", intMinTemp2, strMinTemp2, False)
    Dim intWindSpeed2 = Trim(Mid(RssString, SMarker, Length))
    Dim strWindSpeed2 As String = Trim(Mid(RssString, SMarker, Length + 3))
    MakeDevice("WindSpeed2", intWindSpeed2, strWindSpeed2, False)
    hs.WriteLog("RSS feed", RssString)
    MsgBox(RssString)
    End Sub
    Private Sub MakeDevice(ByVal strDeviceName As String, strStatus As String, strString As String, withIcon As Boolean)
    Dim objDeviceRef As Integer
    Dim objDevice As Scheduler.Classes.DeviceClass
    Dim objStatusText As HomeSeerAPI.VSVGPairs.VSPair
    Dim objStatusGraphic = New HomeSeerAPI.VSVGPairs.VGPair
    'does it exist ?
    objDeviceRef = hs.GetDeviceRefByName(strDeviceName)
    If objDeviceRef <= 0 Then 'it doesn't exist so make it
    objDeviceRef = hs.NewDeviceRef(strDeviceName)
    objDevice = hs.GetDeviceByRef(objDeviceRef)
    objDevice.Location(hs) = "Utility"
    objDevice.Location2(hs) = "BBC Weather"
    objDevice.Status_Support(hs) = True
    End If
    'then update it with status
    hs.SetDeviceString(objDeviceRef, strString, True)
    objStatusText = New HomeSeerAPI.VSVGPairs.VSPair(HomeSeerAPI.ePairStatusControl. Both)
    objStatusText.PairType = HomeSeerAPI.VSVGPairs.VSVGPairType.SingleValue
    objStatusText.Value = 0
    objStatusText.Status = strStatus
    hs.DeviceVSP_AddPair(objDeviceRef, objStatusText)
    'if has a graphic update that
    If withIcon = True Then
    objStatusGraphic.PairType = HomeSeerAPI.VSVGPairs.VSVGPairType.SingleValue
    objStatusGraphic.Set_Value = 0
    If strStatus = "Sunny" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0001_sunny.png"
    ElseIf strStatus = "Light Cloud" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0003_white_cloud.png"
    ElseIf strStatus = "Sunny Intervals" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0002_sunny_intervals.png"
    ElseIf strStatus = "Light Rain Shower" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0009_light_rain_showers.png"
    ElseIf strStatus = "Heavy Rain Shower" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0010_heavy_rain_showers.png"
    ElseIf strStatus = "Thundery Shower" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0016_thundery_showers.png"
    ElseIf strStatus = "Clear Sky" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0008_clear_sky_night.png"
    ElseIf strStatus = "Light Rain" Then
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0017_cloudy_with_light_rain.png"
    Else
    objStatusGraphic.Graphic = "/images/AshTree Weather Icons/wsymbol_0999_unknown.png"
    End If
    hs.DeviceVGP_AddPair(objDeviceRef, objStatusGraphic)
    End If
    End Sub
    Private Function ParseRssFile() As String
    Dim rssXmlDoc As New Xml.XmlDocument()
    ' Load the RSS file from the RSS URL
    rssXmlDoc.Load("http://open.live.bbc.co.uk/weather/feeds/en/2636047/3dayforecast.rss")
    ' Parse the Items in the RSS file
    Dim rssNodes As Xml.XmlNodeList = rssXmlDoc.SelectNodes("rss/channel/item")
    Dim rssContent As New System.Text.StringBuilder()
    ' Iterate through the items in the RSS file
    For Each rssNode As Xml.XmlNode In rssNodes
    Dim rssSubNode As Xml.XmlNode = rssNode.SelectSingleNode("title")
    Dim title As String = If(rssSubNode IsNot Nothing, rssSubNode.InnerText, "")
    rssSubNode = rssNode.SelectSingleNode("link")
    Dim link As String = If(rssSubNode IsNot Nothing, rssSubNode.InnerText, "")
    rssSubNode = rssNode.SelectSingleNode("description")
    Dim description As String = If(rssSubNode IsNot Nothing, rssSubNode.InnerText, "")
    rssContent.Append("<a href='" & link & "'>" & title & "</a><br>" & description)
    Next
    ' Return the string that contain the RSS items
    Return rssContent.ToString()
    End Function
  • mrhappy
    It is going to depend on what is in the script I am afraid (if you want to share it), it is unusual to get forms errors because the majority of scripting commands don't use forms but you might have put something in there that uses it.
  • Script Error 1 Exception has been thrown by the target of an invocation
    I have a script which downloads RSS data from BBC Weather, creates / updates devices (including status graphics) so that that my HSTouch screens update.
    The script works just fine but after it has run I get the following error. ANy ideas where to start looking ? Thank you.
    Running script /usr/share/HomeSeer/scripts/GetRss_and_MakeDevices.vb :Exception has been thrown by the target of an invocation.An exception was thrown by the type initializer for System.Windows.Forms.WindowsFormsSynchronizationContext
