count my current consumed energy
    See my last post for my script , need some help
    is it possible to count my current consumed electricity ?
    i have a virtual that shows the current watts... i want to look the daily consume .. i have a script that writes to csv
    I use plugwise
    can anyone help me ?
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Anyone ?
    i just want to see what i consume in a day...
    i have 4 virtual devices
    1. current electricity : 631W DEVID 3330
    2. Total peak : 1,777.64kWh DEVID 3327
    3. Total Off peak : 2,223.13kWh DEVID 3326
    4. A virtal device DEVID 3329
    Total off peak counts from 21.00 - 07.00
    what script can i use for it ?
      Does nobody have a script for energy usage?
        I have edited this script :
        but it gives me this error , and i dont know what i missed in here ...
        PHP Code:
        p-21 14:38:45         Error    Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\sip_music.vbException has been thrown by the target of an invocation
        PHP Code:
        Const IniFile As String "PowerMeter.ini"
        dim MeterDev As string hs.PluginFunction("Plugwise Pro""""GetTotalPower", {"3382"})
        dim TodayDev As String "PWR-TDY"
        dim YesterdayDev As String "PWR-YDAY"
        dim ThisWeekDev As String "TWD"
        dim LastWeekDev As String "PWR-LASTWK"
        Sub UpdateValues(Optional ByVal parms As String ""
        'Get current and last readings then calculate used value
            Dim LastRead As Integer
            Dim CurntRead As Integer
            Dim Used As Integer
            Try
                LastRead = CInt(hs.GetINISetting("PowerMeter", "LastRead", "0", IniFile))
                CurntRead = hs.DeviceValue(MeterDev)
                If CurntRead >= LastRead Then
                    Used = CurntRead - LastRead
                    hs.SaveINISetting("PowerMeter", "LastRead", CStr(CurntRead), IniFile)
                Else
                    hs.WriteLog("PowerMeter", "Error. Current reading is less than last reading!")
                End If
            Catch ex As Exception
                hs.WriteLog("PowerMeter", "Error getting current reading " & ex.ToString)
                Exit Sub
            End Try
        Update devices
            Dim NewValue
        As Integer
            Dim LastValue
        As Integer
            Dim NewString
        As String
        'For today device
            LastValue = hs.DeviceValue(TodayDev)
            NewValue = LastValue + Used
            NewString = CStr(FormatNumber(NewValue / 100, 2)) & " kWh"
            hs.SetDeviceValue(TodayDev, NewValue)
            hs.SetDeviceString(TodayDev, NewString, True)
        For this week device
            LastValue
        hs.DeviceValue(ThisWeekDev
        NewValue LastValue Used
            NewString
        CStr(FormatNumber(NewValue 1002)) & " kWh"
        hs.SetDeviceValue(ThisWeekDevNewValue
        hs.SetDeviceString(ThisWeekDevNewStringTrue
        End Sub
        Sub ResetCounters
        (Optional ByVal Parms As String ""
        Dim Hr As Single Hour(Now())
        Dim Mi As Single Minute(Now())
        Dim Mt As Single Month(Now())
        Dim Dy As Single Day(Now())
        Dim WkStDay As String "2" 'Monday
        A little check to make sure this function is only run between 00:00:00 and 00:01:00
        If Hr And Mi 1 Then
        'Reset day counters
                hs.SetDeviceValue(YesterdayDev, hs.DeviceValue(TodayDev))
                hs.SetDeviceString(YesterdayDev, hs.DeviceString(TodayDev), True)
                hs.SetDeviceValue(TodayDev, 0)
                hs.SetDeviceString(TodayDev, "0 kWh", True)
                hs.WriteLog("PowerMeter", "Day counters have been reset.")
        Reset week counters
        If CStr(Weekday(Now())) = WkStDay Then
                    hs
        .SetDeviceValue(LastWeekDevhs.DeviceValue(ThisWeekDev))
        hs.SetDeviceString(LastWeekDevhs.DeviceString(ThisWeekDev), True
        hs.SetDeviceValue(ThisWeekDev0
        hs.SetDeviceString(ThisWeekDev"0 kWh"True
        hs.WriteLog("PowerMeter""Week counters have been reset."
        End If
                If
        Dy 1 Then
        'Put code here for month devices reset
                    hs.WriteLog("PowerMeter", "Month counters have been reset.")
                End If
                If Dy = 1 And Mt = 1 Then
        Put code here for year devices reset
                    hs
        .WriteLog("PowerMeter""Month counters have been reset."
        End If
            Else
        hs.WriteLog("PowerMeter""Error. Counters can only be reset between 00:00:00 and 00:01:00"
        End If
        End Sub
