Starting speakers on startup
    With HS2 I used to start the speakers using the following lines in the Startup.script.
    Will they work with HS3, or how could I do it.
    if not hs.IsApplicationRunning("Speaker") then
    lRet = hs.Launch(hs.GetAppPath & "\speaker.exe","Livingroom",,1)
    'hs.waitSecs 60
    'lRet = hs.Launch(hs.GetAppPath & "\speaker.exe","Kitchen",,1)
    hs.waitsecs 60
    lRet = hs.Launch(hs.GetAppPath & "\speaker.exe","Bedroom",,1)
    end if
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    Hi Gordon,
    Yes, that should still work the same. The 1 at the end could likely be changed to a 0 so that it runs with Normal priority, rather than Above Normal.
    Cheers
    Al
      Originally posted by sparkman View Post
      Hi Gordon,
      Cheers
      Al
      Thanks for that. I'll try it when I get back home this weekend.
