Sample code for device control
  • Sample code for device control
    I had downloaded some sample code about a year or so from somewhere on homeseer showing how to control device with CAPI. I have been using CAPI to turn devices on and off for quite a while. Now I want to control a device that dims and set it to a specific dim value. I cannot get this to work with my current code. I can't find the code that I downloaded previously. Does anyone remember where this sample code is located? I believe that it was in some kind of article written my Rich. Or, some other sample code would work as well.
  • #2
    Are you using the CAPIControl.vb script that Rich posted some time back?
    If so you can use it to turn lights on/off/dim. Posted below is a screen shot of 3 test events using the script.
    The example on event turns on the device named "Button A - Table Light (MS)".
    The example off event turns off the device named "Button A - Table Light (MS)".
    The example dim event dims the device named "Button A - Table Light (MS)" to 33%.
    I also attached the VB script as a text file (remove the .txt extension)
    Hope this helps.
    Billy Draper
    • #3
      Here's an example of a small script that sets a dim value using CAPI:
      Sub Main(ByVal Parms as String)
      	Dim ParmArray() as String
      	ParmArray = Parms.tostring.split(",")
      	dim targetDev as Double = CDbl(ParmArray(0))		'reference ID of the device to use for existing value
      	dim targetDim as Double = CDbl(ParmArray(1))		'reference ID of the device to set based on value of targetDev1
      	hs.CAPIControlHandler(hs.CAPIGetSingleControl(targetDev,false,targetDim,false,true))
      	hs.writelog("Dim Script","Set New Dim: " & targetDim)
      End Sub
      HS 3.0.0.548: 1990 Devices 1172 Events
      Z-Wave 3.0.1.262: 126 Nodes on one Z-Net
      • #4
        You may also find that tenScriptAid is a useful tool.
        HS3 Pro Edition 3.0.0.548
        HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
        • #5
          I got it working
          [ATTACH]56722[/ATTACH]
          Hope this helps.
          I got it working using the sample. The script attachment was exactly what I was talking about in the original post. I will put that in a safe place for future reference.
          • #6
            Good deal, glad you got it working.
            Billy Draper
            • #7
              Thank for the info
              I am a big fan of Ed Tenholder's Tenscripting tool. I use it for all my vb development. Makes the effort so much easier.
              I was not aware of the TenScriptAid tool. Looks like another great tool from Ed for Homeseer vb development.
              • #8
                Jim,
                The support request you sent me had a bad return email address. Let me know if you got my response.
                tenholde
                tenholde
