Puzzled Script conditions being ignored
    The followsing scipt all conditions are ignored.
    sub main()
    Dim a
        Dim b
        Dim c
        Dim d
            Dim x
    x = Replace(x,"-","minus ")
    hs.speak "Good "& TimeOfDay() & ".. The time is " & myTime() & "..It is" & WeekdayName(DatePart("w", Date)) & MonthName(DatePart("m", Date))& ",,the" &  myday() & "," & "and the current outside temperature is $$Dsr:408: .."
      If hs.IsOff(335) Then
            hs.Speak "..Gordon is at $$DSR:58:" & "$$DSR:50:"
    end if
      If hs.IsOff(440) Then
            hs.Speak "..Suzanne is at $$DSR:438:" & ".$$DSR:430:.."
    end if
      If hs.IsOff(68) Then
            hs.Speak "Landy is at $$DSR:46:" & ".$$DSR:38:"
    end if
    end sub
    Abiet the divices being checked do not have "off" in the deviced string, they have "Not Near" although the valie is 0 Off.
    Anyone through any light on my problem?
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    You might try replacing hs.isOff. With hs.devicevaluex. I'm not sure that hs.isOff works with HS3.
    Steve Q
      Steve Q
      Thanks Steve, tried that, had no effect on HS3 at all, no errors nothing, just ignored.
        See this post for a working example:
        http://board.homeseer.com/showthread.php?t=162986
        -Rupp
          Great link, thanks Rupp, one small problem I require to use the refferance code as the divices are not X10.
