The followsing scipt all conditions are ignored.
Abiet the divices being checked do not have "off" in the deviced string, they have "Not Near" although the valie is 0 Off.
Anyone through any light on my problem?
sub main() Dim a Dim b Dim c Dim d Dim x x = Replace(x,"-","minus ") hs.speak "Good "& TimeOfDay() & ".. The time is " & myTime() & "..It is" & WeekdayName(DatePart("w", Date)) & MonthName(DatePart("m", Date))& ",,the" & myday() & "," & "and the current outside temperature is $$Dsr:408: .." If hs.IsOff(335) Then hs.Speak "..Gordon is at $$DSR:58:" & "$$DSR:50:" end if If hs.IsOff(440) Then hs.Speak "..Suzanne is at $$DSR:438:" & ".$$DSR:430:.." end if If hs.IsOff(68) Then hs.Speak "Landy is at $$DSR:46:" & ".$$DSR:38:" end if end sub
