Thermostat script
    Thermostat script
    Can someone help me please???
    The z-wave thermostat I have in my house, the auto doesn't seem to be working to switch between heat and cool when the temp drops below its set point. I have hoping someone could help me with a simple script (I assume and hope it would be simple). I always have my set points two degree difference and was hoping for a script instead of a million different events for each temp setting.
    If: thermostat set to heat
    And If: temp is above cool set point for atleast X amount of time
    Then: turn to cool
    And
    If: thermostat is set to cool
    And if: temp is below heat set point for atleast X amount of time
    Then: turn to heat
    You could use a script, I use below script to decide if my AC should be off, come on low or high depending on temperature. You could add cases for temperature below x and trigger an event to turn the AC or thermostat to heat.
             Dim Temperature As Double
            Temperature = hs.DeviceValueEx(18)
             Select Case Temperature
                 Case < 20.4
                    hs.TriggerEvent("AC off auto trigger")
                 Case 22.0 To 23.5
                    hs.TriggerEvent("AC on low auto trigger")
                 Case > 23.5
                    hs.TriggerEvent("AC on high auto trigger")
             End Select
         End Sub
